Forums >> Revit Building >> Technical Support >> Controlling Yes/No Parameters with Formula
Fri, Apr 1, 2005 at 7:36:05 AM | Controlling Yes/No Parameters with Formula
Lee Sowerby
I have a standard yes/no parameter for Visibilty of an item. I would like the Item to be visible, therefore "ticked", if the Base depth = 500mm, or 400mm, or 300mm, or 250mm but not ticked with any other Base depth dimension. I have tried all sort of formula but have failed so far. I cannot have the formula Base depth > 99mm as I will have dimensions in between the onse stated.
Fri, Apr 1, 2005 at 9:35:50 AM | RE: Controlling Yes/No Parameters with Formula
Lee Sowerby
Hi All, Please ignore this as i have now suused it.............I simply created a interger parameter with the needed formula in it and then referenced the ye/no parameter to it's result............sorry for asking Lee
Thu, May 29, 2008 at 5:48:15 AM | Controlling Yes/No Parameters with Formula
AndyHarle
AndyHarle Avatar
I am struggling with this and have not worked out how to set the Yes/No parameter with an If statement.
I have tried IF(Integer=3,Yes,No) and variations with True, False 1,0 and with 'Yes', 'No' but without success
Can anyone spell it out to me?
thanks
Andy Harle
Revit 2021
Thu, May 29, 2008 at 7:12:02 AM | Controlling Yes/No Parameters with Formula
Dafpfy
3.5 Stars: 11 Votes
this is what revit help says about this,
IF with Yes/No condition: =Length > 40 (Note that both the condition and the results are implied.)
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Thu, May 29, 2008 at 7:53:19 AM | Controlling Yes/No Parameters with Formula
AndyHarle
AndyHarle Avatar
Thanks,
I should have searched the Help, but i started on the Tutorials wher it doesn't mention the syntax
 Yes it does work
=variable=3 - sets the yes/no variable to yes if variable=3
Revit 2021
Formula with YES/NO Parameters
Tue, Jun 6, 2017 at 1:58:42 PM
Controlling Visiblilty Of Multiple Families
Sun, Nov 4, 2012 at 10:16:48 AM
Enter formula anywhere a number is required
Tue, May 8, 2012 at 10:57:12 AM
basic formula question regarding parameter use
Wed, Jun 16, 2010 at 5:34:23 PM
Revit 2010 family parameters formula and room tag
Fri, Aug 7, 2009 at 4:28:34 PM
Page generation time: 0.1484
