Forums >> Revit Building >> Technical Support >> Frame line elevations
Fri, May 16, 2008 at 9:03:10 AM | Frame line elevations
kbsheppard
We have noticed a change in RST09 to the frameline elevations that makes it harder to work with and I wonder if anyone else has the same problem (or a sloution).....Framelines can only be taken at the grid line, ok great BUT we want to be able to the girts on the outside as well. OK so take the elevation on the inside and look outwards, great BUT now we can't see the joists framing into the beams. Our workaround is to make pure elevations and just turn off all non-stru. elements. Great BUT we'll never use the frameline tool and shouldn't we use the stru. tools to do stru. things??
Door and Frame Types (elevations) question
Tue, Feb 25, 2020 at 3:11:18 PM
2014 Level Head Adjustment in Sections/Elevations/Etc.
Thu, Mar 13, 2014 at 1:08:44 PM
Frame & Door Type Elevation Drawing
Sat, May 31, 2008 at 10:49:00 PM
exterior elevations and line weights
Fri, Jul 20, 2007 at 12:06:07 PM
Help with Frame generator
Tue, Feb 24, 2015 at 8:09:16 AM
Page generation time: 5.8900
