Forums >> Revit Building >> Technical Support >> Uniformat
Thu, May 15, 2008 at 6:37:04 PM | Uniformat
rgarc123
Hi,
I would like to add a uniformat code but can't find the way to do it ex:
Windows  : There is a code for aluminum , steel and wood windows . In many project either institutional or residential we use PVC windows  how do I add the code.
Rem
Thu, May 15, 2008 at 7:17:43 PM | Uniformat
Leslie
In your revit program files you will find a .txt file called
uniformatclassifications.txt
Open it in notepad and edit...be careful to format the tabs etc correctly...
you may need to restart revit to get it to read your changes...
Tue, May 20, 2008 at 5:22:34 PM | Uniformat
rgarc123
Thanks
Omniclass & UniFormat
Thu, Oct 27, 2011 at 10:44:55 AM
Uniformat Assembly Codes: Revising
Tue, Oct 7, 2008 at 3:52:19 PM
Uniformat assembly codes
Thu, Jan 31, 2013 at 11:21:11 AM
about the uniformat codes
Wed, Jan 28, 2009 at 6:17:09 AM
organizing components
Wed, Feb 11, 2009 at 10:47:15 AM
Page generation time: 0.0162
