Forums >> Revit Systems >> Technical Support >> Modifying stairs to use custom steel stair pan
Thu, May 15, 2008 at 3:12:10 PM | Modifying stairs to use custom steel stair pan
unclee87
I'm creating steel stair fabrication plans for a client using Revit Arch. 2009, and am trying to figure out if there is a way to modify stair properties to use a custom steel stair pan in place of the standard "riser" and "run". I found a steel stair pan within revit, but other than arraying it in a drafting view on top of my automatically generated stair section, I'm not sure how to use it. Also, I need to modify the properties of the stringers to be C-shapes... Any help is welcome!
ejh
Fri, May 16, 2008 at 1:01:00 AM | Modifying stairs to use custom steel stair pan
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes, an annoying shortfall with the stair tool.
I would suggest you use the railing tool to do the stringers and treads or do them as separate families.  The stair tool will not allow you to create a stair at this detail conventionally.
Regards,
Chris.
steel pan visibility in 3D view ?
Sun, Jun 4, 2017 at 1:49:03 PM
Steel pan Decking
Wed, Feb 4, 2009 at 1:11:27 PM
Steel Stairs with Channel Stringers
Wed, Jun 7, 2006 at 11:33:30 AM
Steel Pipe Railing
Fri, Mar 31, 2017 at 10:35:43 PM
Stair Shaft Creation
Sat, Nov 15, 2008 at 7:38:04 AM
Page generation time: 0.7886
