Forums >> Revit Building >> Technical Support >> Line-based model bug
Thu, May 15, 2008 at 1:29:28 PM | Line-based model bug
stang
I created a line-based "base cabinet" model.  ( the gable and doors repeats)  It works fine on Ground and Third floor, but it doesn't work on Second Floor.  I really cannot figure out why.  Does anyone has a clue?
Thu, May 15, 2008 at 1:50:53 PM | Line-based model bug
stang
I changed the model graphics style from wireframe to hidden line.  Then the line-based model works.
If anyone has a clue to the reasoning behind this, i would like to know.  Thanx.
Fri, May 16, 2008 at 1:46:13 AM | Line-based model bug
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
When you place most elements they generally default to face workplane placement.  In wireframe there is no faces so it can't place the element.  Had you have switched to workplane placement it would have placed the element.
HTH.
Regards,
Chris.
Mon, May 26, 2008 at 11:58:31 AM | Line-based model bug
stang
Mr Spot
I am having trouble again with the line-based family.
Is there anyway to stop Revit from rounding up integers?  My "no of gables = (Length/spacing)+1", as the number rounds to the closest integer, sometimes i have an extra gable.
thanks
Line based generic model family- RAC2008
Wed, Apr 22, 2009 at 12:00:15 PM
Family Typical Model based on line
Mon, Dec 22, 2008 at 7:55:47 AM
Line-Based Detail Families - Pick Line Option Gone?!?!
Mon, Sep 5, 2011 at 8:25:00 AM
Is it possible to make a line-based family wall based?
Wed, Jan 5, 2011 at 1:00:21 PM
Line Based Family Won't Join at Ends
Mon, Apr 10, 2023 at 8:13:57 AM
Page generation time: 0.7298
