Forums >> Revit Building >> Technical Support >> Duplicating Materials in 2009
Thu, May 15, 2008 at 9:46:53 AM | Duplicating Materials in 2009
AmberW
In the past, we were able to duplicate materials during the rendering stages of our design with the acurender engine. We are having trouble duplicating materials in 2009 with the new mental ray engine. Is it possible to duplicate materials in 2009? If so, how can this be done?
Thu, May 15, 2008 at 2:12:36 PM | Duplicating Materials in 2009
JustinT
Can you explain the problem a bit more? you can still go into the Material dialog and the button at bottom left allows you to duplicate a material in the same manner as 2008 - but do you mean when you try to create your own render material and use that in the material definition as this part has changed, with the introduction of the Pro Materials
http://www.revitup.co.za/main/page_home_2009_guide_revit_goes_mental.html
Justin
Thu, May 15, 2008 at 2:31:13 PM | Duplicating Materials in 2009
AmberW
Yes,  We have created our own material and are trying to duplicate it.  Is this possible in '09?  If so how do we do it?
 Thank you,
Fri, May 16, 2008 at 1:16:25 AM | Duplicating Materials in 2009
JustinT
In Materials Dialog box first Duplicate a material (bottom left button)
Next on the Render Appearance tab click the Replace button to select at material image from the library.
Now in the look down for the area than specifies the Image File and click browse to select your own BMP or JPEG etc.
Adjust the various settings to desired result e.g. Finish, bump map etc then back up the top part of the dialog box click the Update Preview button. Voila new material.
 Justin
www.revitup.co.za
REVIT 2009 - MATERIALS
Tue, May 5, 2009 at 10:01:40 AM
13
duplicating views without duplilcating callouts or view tags
Wed, Sep 11, 2013 at 3:09:15 PM
New materials RAC 2009 and or new skies/backgrounds/environments??
Thu, Jan 22, 2009 at 7:03:18 PM
materials appearance - revit 2009
Thu, May 29, 2008 at 1:11:15 PM
using revit 2008 project in revit 2009...plz help
Tue, May 27, 2008 at 8:44:38 AM
Page generation time: 0.9536
