Forums >> Revit Building >> Technical Support >> hipped roof beam
Thu, Mar 31, 2005 at 7:33:02 PM | hipped roof beam
kate
I'm having trouble creating a hipped I-beam. I used a reference plane that was aligned in plan to the hip ridge but was unable to snap one end to the underside of the roof geometry in order to locate the beam precisely. In other words, how do you draw a structural member in plan then align it to a specific point in the z direction?
Thu, Mar 31, 2005 at 9:37:20 PM | RE: hipped roof beam
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
When you draw the structural beam in section/elevation it will create another reference plane that it will associate its level to. To lock to the roof, lock this reference plane to the underside of the roof. HTH.
Double sloped hipped roof
Mon, Jun 27, 2011 at 2:18:55 AM
Creating a Dormer in Hipped-Gable Roof.
Fri, Oct 5, 2007 at 7:15:11 AM
Gablet to hipped end roof.
Fri, Apr 23, 2004 at 3:40:44 AM
Roof, Roof, Tower and nary a boolean to be found
Thu, Apr 8, 2010 at 5:02:02 AM
Hip roof problem
Wed, Feb 27, 2008 at 5:28:59 PM
Page generation time: 3.2409
