Forums >> Revit Building >> Technical Support >> Windows are transparent. I want to make them toned when rendering
Thu, May 15, 2008 at 7:17:46 AM | Windows are transparent. I want to make them toned when rendering
torstenk
Hi all
When im rendering my building the windows look transparent. It would be nice if i could tone them. Do anyone know how?
Ive attached a render where i quickly attached the render so you can see what i mean
Thu, May 15, 2008 at 7:24:35 AM | Windows are transparent. I want to make them toned when rendering
torstenk
Oh and btw i have used split face to make colours on my falls. Why dont they show in my rendering?
Thu, May 15, 2008 at 9:31:19 AM | Windows are transparent. I want to make them toned when rendering
4 Stars: 205 Votes
What kind of windows do you put in the model? do you change the materials of the windows Family?
It's strange appears like that...
Thu, May 15, 2008 at 9:46:38 AM | Windows are transparent. I want to make them toned when rendering
torstenk
I have just normal windows. Ive only changed the size. It is some that are in our danish library. The big ones in the front are curtain walls.
theres also glass in the window if that is what you mean?
Thu, May 15, 2008 at 9:57:11 AM | Windows are transparent. I want to make them toned when rendering
4 Stars: 205 Votes
I think you do this: change the material of your windows, put a red color in that to see and look if appears in the model, if so, zoom the model and render, put the image here to see what happen ok?
Thu, May 15, 2008 at 9:58:26 AM | Windows are transparent. I want to make them toned when rendering
torstenk
Ive figured out to change it. I changed the material called "glass" in "accurender" from  _ACCURENDER\Glass\Clear,Smooth to _accurender\Glass\Clear,Rippled, Light
 Does anybody know why my renderings dont show the painting i have done on my splitface? I have made splitfaces to make different colours on the wall, but it doesnt show on my renderings?
Thu, May 15, 2008 at 10:10:32 AM | Windows are transparent. I want to make them toned when rendering
4 Stars: 205 Votes
When you splitface the wall you change the material in that wall? or have the same material the others? you can change the color in a wall but when you render appears the material you did assigned to the wall...
Thu, May 15, 2008 at 10:19:44 AM | Windows are transparent. I want to make them toned when rendering
torstenk
When you use the paint tool it doesnt do anything to the actual wall. Its just like a "outer layer" on the wall.
If you see my attached picture i have used split face to make a like a cross in the wall. I have done this by using split face.
But when i render it this colour doesnt show. And that is not right Smile I want it to show my split face and the painting i have done in it Smile
Thu, May 15, 2008 at 11:07:11 AM | Windows are transparent. I want to make them toned when rendering
4 Stars: 205 Votes
Yes, i know that, what i'm saying is if you change the materials in those walls (walls with split faces)? not only the color but also the material....
Thu, May 15, 2008 at 2:04:40 PM | Windows are transparent. I want to make them toned when rendering
JustinT
Yup what Typoon is saying is that you probably created a new material to paint with but only applied a colour for the shading I think... double check the material and make sure it has an accurender material applied as well. if you just want it to render with a solid colour etc you still have to specify one from the accurender library - this is the only thing I think it could be.
Justin
 www.revitup.co.za
Thu, May 15, 2008 at 2:27:08 PM | Windows are transparent. I want to make them toned when rendering
#11
torstenk
Ah yes i see now. Now it is perfect. Thanks for all your help. Both Typhoon and JustinT Smile
rendering windows in 2009
Wed, Aug 27, 2008 at 8:35:01 AM
Rendering problems with existing phase
Tue, Sep 19, 2006 at 2:24:36 PM
Transparent textile in rendering
Thu, Jan 6, 2011 at 8:43:04 PM
Rendering windows
Mon, Apr 24, 2006 at 7:58:43 AM
Glass keeps rendering black not transparent
Mon, Jan 23, 2006 at 4:01:41 AM
Page generation time: 1.6230
