Forums >> Revit Building >> Technical Support >> Need help finding or creating SHUTTERS
Wed, May 14, 2008 at 10:18:08 PM | Need help finding or creating SHUTTERS
srichar
i am new to the program but have had good success. but i cannot figure out how to create window shutters. i also cannot find any. i need these ASAP. anyone?
Thu, May 15, 2008 at 2:53:23 PM | Need help finding or creating SHUTTERS
unclee87
If you have access to the 2009 online content library you can find it at this location: Revit Architecture 2009 Library/US Library/Families/Misc. Architectural. If you don't have 2009 I think you're out of luck... can't remember if they had it then or not, but I'd check in the same location.
ejh
Fri, May 16, 2008 at 8:18:10 PM | Need help finding or creating SHUTTERS
srichar
great. now that i have found a pretty paltry shutter, i need to ammend it. i am actually using the shutter as an operable sun shading device. i do not want it green. when i go under materials i cannot change it. i need to set a parameter. i am only a few days into this program and have figured a lot out but not this. guidance? i want dark wood shutters. how can i do this.
 i also need to add more louvers to it and i cant quite figue this out other than creating a family within a family.
thanks
Sat, May 17, 2008 at 3:59:41 PM | Need help finding or creating SHUTTERS
4 Stars: 205 Votes
Hi, you can try to pick in that shutters and go to properties and see if it have the material component to can change, otherwise pick in shutters and edit family, in there you can see how it's created, the materials name and you can change in there...
Why doesnt Revit have shutters?
Tue, Oct 19, 2010 at 2:49:13 PM
Painted Raised panel shutters
Sat, Jul 22, 2017 at 9:18:15 AM
Double Skin facade with folding shutters
Tue, Nov 12, 2019 at 9:31:43 PM
How do I draw Bermuda shutters?
Thu, Mar 11, 2010 at 2:07:45 PM
Swing(able) hinged shutters
Fri, Jan 15, 2010 at 11:37:47 AM
Page generation time: 0.3690
