Forums >> Revit Building >> Technical Support >> Mullion will not load
Wed, May 14, 2008 at 10:27:03 AM | Mullion will not load
rfrusso
5 Stars: 2 Votes
My drawing got purged of all unused items and now I am left with a project that has no mullions in it. When I try to add a mullion I do the following: Load from family, navigate to the profiles, find a mullion profile in the curtain wall directory and select it. Then when I click on the mullion icon in the modeling tab, I get a message saying "no curtain wall mullions family is loaded in the project. Would you like to load one now?"
So where do I find them? If they are not located in the curtain wall mullion folder, where would they be?
Wed, May 14, 2008 at 11:14:48 AM | Mullion will not load
Mullions are a profile.  Look in that folder or create your own profile under the correct category.
Wed, May 14, 2008 at 11:39:54 AM | Mullion will not load
rfrusso
5 Stars: 2 Votes
Right, I get the profile thing. That is where the issue is. If I go into the profiles directory, and then into curtain wall and select a curtain wall mullion profile, I still get the same message. So if the path that I followed isn't going to the correct family type, then where would I go to find the right family type for a mullion profile?
Wed, May 14, 2008 at 1:31:23 PM | Mullion will not load
lunchtrayrider
3.5 Stars: 7 Votes
copy paste a curtain wall and a mullion into the project to have something to start with.  this should solve the loading the profile (because im guessing every time you open a profile it says family is of the wrong category, correct?)
follow this and then see if you can't find it.
 modeling>mullion>type properties>duplicate>rename
under construction there should be a profile. select the drop down and select the profile you want.
this should work especially since you already loaded a profile.  let us know if it doesn't.
Wed, May 14, 2008 at 4:50:44 PM | Mullion will not load
rfrusso
5 Stars: 2 Votes
I had already did the copy and past thing, but it hadn't occurred to me to then try to load a new profile at that point. So... um... yeah, that totally worked! Sweet thing too, because the profile that I actually wanted was a 6" flat guy at a 45 deg. angle. I was trying to use the mullions to simulate a mechanical screen.
Tue, Jun 24, 2008 at 11:03:55 AM | Mullion will not load
ehreese
This is not working for me, as I have no curtain wall or mullions to copy/paste. Any thoughts?
Tue, Jun 24, 2008 at 11:34:41 AM | Mullion will not load
lunchtrayrider
3.5 Stars: 7 Votes
you open a new project and make a curtain wall with the mullion you want in it.  then you copy from one project to the other.  then its in.
Tue, Jun 24, 2008 at 11:39:38 AM | Mullion will not load
ehreese
It worked! Thanks so much. I appreciate it!
Tue, Jul 22, 2008 at 8:20:07 AM | Mullion will not load
mcoffey
You don't have to copy and paste a curtain wall from another project. In the Project Browser under Families there is a listing for Curtain Wall Mullions. First load a curtain wall profile using File/Load from Library/Load Family.... Then under Curtain Wall Mullions there are 6 types. These 6 types can't be purged out. Right click on the shape you want and click on New Type and give it a name. Then in the properties of this newly created mullion type you can apply your mullion profile.
L Corner Mullion - Can't load profile
Wed, Oct 9, 2013 at 4:37:25 PM
problem with mullion
Sat, May 12, 2012 at 8:31:22 AM
mullion ang transom not fitting well [ 1 2 ]
Wed, Oct 9, 2013 at 11:42:10 PM
23
Adding New Mullions to your Mullion Tab Options
Wed, May 11, 2011 at 5:51:35 PM
Curtain Mullion eats into vert mullion
Thu, Jan 22, 2015 at 4:49:08 PM
Page generation time: 1.0472
