16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Split doesnt look right
28 Posts No Rating |
Hi all Im making a interior elevation plan. Then i have used paint to show that i have tiles. But it doesnt make the right endings. See attached pic. How do i change this? Using Revit 2008
u can use the align tool to move face materials
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Wont i move the wall then?
nope, select align select the edg of the wall that is in section and select a vertical lign of your tiles,
peace is the path."
Mahatma Gandhi.
youre right thx!! What does this mean? The closed loop used to split the face must lie completely within the face and cannot intersect or overlap any of the face's edges. To split a face at its border, use an open loop that ends on the boundary of the face.
Dont have a clue
peace is the path."
Mahatma Gandhi.
You get this message when you use the split face tool. It is telling you that you have drawn a closed area and its boundary is either touching or overhanging the wall edge. You will need to do one of two things; either draw the boundary entirely inside the wall extents without touching the edge or remove some lines to make the endpoints of sketch lines touch the extent edges of the wall.
Split face aournd a corner... |
Tue, Aug 25, 2009 at 2:14:22 PM
Making a Clean Split |
Sun, Jul 11, 2010 at 1:51:14 PM
Need a help |
Wed, Feb 25, 2015 at 7:20:52 AM
Split face on floor? |
Wed, Nov 18, 2015 at 1:16:28 PM
Edit Split Face on Ceiling |
Mon, Jan 25, 2010 at 4:42:26 PM
