Forums >> Revit Building >> Technical Support >> Reference a "grand total" from a schedule??
Tue, May 13, 2008 at 3:18:44 PM | Reference a "grand total" from a schedule??
audisnapr
3 Stars: 6 Votes
is it possible to reference a grand total from a schedule?  for example, here in NY we have to show schedules and diagrams of our "gross building areas", the "deductions areas" and then subtract one from the other to get our "zoning area" (to put it simply).  Once these three schedule are all dialed-in, we have 3 numbers that we'd like to show on your "zoning sheet" - it looks something like this:
gross(sf) - deductions(sf) = zoning(sf)
at the moment we have to enter the grand totals from our schedules into the above "formula" manually - but of course like any coordination, sometimes it gets overlooked.  I'd like for it to be automatic; anytime we make a change to either the gross or deduction areas it automatically updates not only all the schedules, but updates the simple formula on the zoning sheet.
I've tried to make duplicates of the schedules and show only the grand totals (to drop onto the zoning sheet), but this doesn't seem to be possible.  Any suggestions?
Tue, May 13, 2008 at 4:01:03 PM | Reference a "grand total" from a schedule??
audisnapr
3 Stars: 6 Votes
<<edite>>
this is for Revit 2008, btw.
also, I don't need the formula on the zoning sheet to "work"; meaning I don't need the numbers to be calculated.  If I could simply get the grand totals to appear on the sheet, the gross will show as a positive, the deductions will show as a negative, I can add an (=) symbol and then just show the total zoning area.
Wed, May 14, 2008 at 1:37:44 PM | Reference a "grand total" from a schedule??
audisnapr
3 Stars: 6 Votes
bump - any thoughts on this or even a work-around?
Wed, May 14, 2008 at 2:43:29 PM | Reference a "grand total" from a schedule??
lunchtrayrider
3.5 Stars: 7 Votes
were you able to make a schedule to get all the totals?
I like scooters. and motorcycles.
Wed, May 14, 2008 at 2:52:21 PM | Reference a "grand total" from a schedule??
audisnapr
3 Stars: 6 Votes
yeah, I have no problem getting the totals I need.  I just need to be able to get that total to show up, by itself, on different sheets of an architectural set of drawings.
if this is even possible, there are several areas I could use this, ie: apartment areas (total area only) show in the apartments themselves on the construction documents as well as the zoning analysis sheets.
Wed, May 14, 2008 at 4:24:32 PM | Reference a "grand total" from a schedule??
Remember, you can always have calculated fields that may use hidden fields and you can have more than one schedule that uses the same data.
Wed, May 14, 2008 at 5:11:36 PM | Reference a "grand total" from a schedule??
audisnapr
3 Stars: 6 Votes
correct.  tried that.  problem is, I only need the grand total to show.  you can't hide all the columns, only all but one.  the schedule is so intensive that it becomes a hundred or so rows long and there is no way to hide the rows.
to make it a little more clear, in order for the building department examiner to verify that the apartment's gross is what we say it is, we have to break down each part of the apartment into a box/triangle and indicate a length and width of the box in the schedule so that the examiner can sit there and calculate the "actual" apartment size to verify our plans.  when doing this, you tend to end up with several boxes/triangles that make up the entire apartment.  we've developed a generic model and a few parameters to show up in a schedule so that each box's length is multiplied by its width (this is where revit's areas fall short - that actual area of a box is not always the same as if you multiply length times its width using 1/16" as the lowest unit fraction - yeah, I know, its nuts).  Anyway, when you add up all the boxes for all the apartments of all the floors, you get a pretty lengthy schedule and there is no way to hide all the information except the grand total.
there are a few reason this is so important.
1 - our mezzanines can only be 1/3 of the floor below that it is attached to.  So obviously we make every effort to maximize this 1/3; down to the .01 SF
2. - the zoning area is also another place we (as NY architects) try our very best to give the client their maximum allowed build-able area, again, down to the .01SF
So keeping all of this information automated is very important - move a wall - everything needs to update so that an examiner does not find a discrepancy in your math :-)
in short, I've tried everything I've learned in revit from the past 6 or 7 years that I've been using it and nothing really seems to work as a work-around.  and from what I can find there is no way to simply reference the grand totals from a schedule.
Edited on: Wed, May 14, 2008 at 5:12:35 PM
Wed, May 14, 2008 at 10:17:04 PM | Reference a "grand total" from a schedule??
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Try this,
Duplicate your schedule Cryingit should only consist of the area field and the field we'll create below)
add a new text parameter called Gross.
Now enter the text "Gross" in all your rows.
Now sort the schedule by the field "Gross"
Ensure itemize every instance is turned off.
Ensure the field for area is set to "calculate totals"
Set the schedule not display a grand total or name.
Hide any unwanted columns...
This should give you what you need.
Regards,
Chris.
Thu, May 15, 2008 at 8:45:03 AM | Reference a "grand total" from a schedule??
audisnapr
3 Stars: 6 Votes
Mr. Spot - I told my co-worker here that if he solved this problem that I would get down and bow to him before the rest of the brooklyn born italian co-workers in this office.  Apparently I need to redirect my praise to you.
I really don't understand why this works, but it does in fact, work.  I hid all of the columns, including the "gross" column, except for the, in our case the "calculated total" column.  Doing this show's one cell with the grand total in it.  Again, I don't understand why it works because the "grand total" usually shows up outside of the cells down in the gray area of a schedule.  To further make the number show up correctly, in the appearance section I unchecked all the boxes so there are no frames, titles, grids, etc.  When this new schedule is dropped on to a page, the only thing that shows up is a single number (in SF) with no frames or anything.  PERFECT.
If you have the time, I'd like to hear why this works.
Thanks again!!!
Wed, Oct 7, 2015 at 12:45:57 PM | Reference a "grand total" from a schedule??
cantcacheme
This solution will be a good work around for me and my project.  I have square footages of rooms I need to portray and my room schedule won't all fit on one page.  As such, the normal way to divide up schedules on columns is to use the filter options within Revit.  That works great until you need to display the grand total for all of the rooms, which are different schedules now.  Creating another schedule as outlined here just shows the grand total of the rooms.
I'm certainly not a Revit guru, but I imagine that this works because every item is not itemized, and also because every row has the same value shown, aka "Gross".  Revit then takes every "Gross" it sees and combines it into one row.  The same would work if it was all blank or any other word you choose.  This seems to be the case because when I type another word, such as "test" into my "Gross" column for one of my rooms, after I uncheck the itemize box, I end up seeing two rows.  One called "Gross" and the other called "test" with respective totals for each.  Thanks Mr. Spot for the work around!
Area schedule question: "Grand total" in formulas...
Thu, Nov 26, 2009 at 5:54:29 AM
Schedules
Thu, Oct 27, 2005 at 3:06:04 PM
Schedule Count as Percent of Grand
Thu, Dec 22, 2011 at 10:33:17 AM
Grand total text
Wed, Oct 21, 2009 at 11:14:58 AM
Schedule sub total
Sun, Jul 9, 2006 at 10:29:50 AM
Page generation time: 2.1288
