Forums >> Revit Structure >> Technical Support >> masonry lintels
Tue, May 13, 2008 at 12:59:35 PM | masonry lintels
minfante
We're relatively new revit structure 2008 users.  We purchased 2009 and will have it installed soon.
What is the best approach to place masonry lintels in a model.  Are families required?  Are they components?  Can they contain analytical parameters?  Our intention is to mark them and schedule them with tabulated data, like footings.  Your ideas can be in general detail, since we've learned quite a bit about the software.
Tue, Jun 10, 2008 at 12:16:31 PM | masonry lintels
Khakhan
Khakhan Avatar
I would like to know this also...
Revit 08,09 user
Tue, Jun 10, 2008 at 3:05:28 PM | masonry lintels
4 Stars: 205 Votes
Hi there, I do not feel the Will with Revit Structure but you can create your model or family Lintel like do you want to insert in your models, you can give them materials and they appears in shedules and they can be tagged in view...
I think you must search in others AUGI forum about Revit Structure...
Thu, Jun 12, 2008 at 8:47:00 AM | masonry lintels
MartinGT
1 Stars: 1 Votes
If you make a family for the lintels in that you can add the info that you need to pull off on the schedules (mark, type etc).  You will need to look at the help for making familesa and using shared parameters.
Thu, Jun 12, 2008 at 12:58:13 PM | masonry lintels
carlos123
I went into my edit wall assembly and added a sweep to the top of the wall.  I created the sweep from a profile earlier.  It seems to work well for my uses.
How to create masonry or concrete lintels and display them correctly?
Fri, Apr 9, 2010 at 3:42:59 PM
Lintels in Revit Structure
Mon, Nov 5, 2007 at 10:31:29 AM
masonry walls?
Tue, Jun 22, 2010 at 5:35:51 PM
LINTELS
Tue, Sep 11, 2007 at 12:52:11 PM
concrete wall and masonry wall to have different lineweights
Thu, Jan 6, 2011 at 12:39:04 PM
Page generation time: 0.3179
