Forums >> Revit Building >> Technical Support >> Creating a cupola
Tue, May 13, 2008 at 12:54:23 PM | Creating a cupola
ashleyngriffith
Does anyone know how to create a cupola that has an octagon base and the shell itself contains 8 sections?
Tue, May 13, 2008 at 2:33:17 PM | Creating a cupola
SEdwards
Are you using 2008 or 2009? I did a cupola in 2008 and I used the massing tools. It took some playing around with to get what I wanted. The massing tool was the easiest. I had tried using the roof tools at first and that was a mess. Maybe the solid blend or extrusion would be useful under massing. Play around with the voids too. Sorry I couldn't be of more help. If you search for domes in this forum you might get a better idea on how to handle massing.
-Stephanie
Cannot get Sweep Form to Work
Wed, Jul 2, 2008 at 6:58:12 PM
how to creat a doom roof
Fri, Sep 5, 2008 at 4:28:48 AM
creating vehicles
Thu, Nov 16, 2006 at 12:18:26 PM
Creating a PLT file directly from Revit for sending to HP 750 plotter, how?
Mon, Sep 24, 2007 at 10:22:46 AM
Creating window check reveals
Fri, May 6, 2016 at 10:16:00 AM
Page generation time: 1.3277
