21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Revit Structure 2009 printing
Hello, I am hoping someone could help me out with printing. I manage to print a sheet (foundation plan) then I tried to print the roof framing plan and I had a message that shading was turned on. I turned that off then I tried to print once again and I keep getting the message " PRint Job could not be sent" can some one give me ideas as to why this is happening and how I could fix it? Cheers! Vanrevit
Welcome to the REvitlution!!! |
i think i can help. i use 2008, but it should be sim. i have 2009 trial but have not played with it. when you create you sheet in a level or even 3d, once you finish placeing it, go to you file menu (upper left) drag down to publish 2d dwf... once you get it in the dwf viewer you can print to adobe or just out of you printer. tip before you set your sheet, hide any thing you dont want on the print. like level lines ext.
Thank you kindly
Rendering in Revit Structure 2009? |
Sat, Dec 24, 2016 at 5:11:53 AM
SketchUp into Revit Structure 2009 |
Fri, Feb 27, 2009 at 9:51:24 AM
Revit 2009 Arch Struc User Guides/Tutorial Books pick up in LA |
Wed, Feb 10, 2016 at 7:28:35 AM
Revist Structure 2009 - Where are Light Fixture families located??? |
Tue, Oct 21, 2008 at 2:54:02 PM
Revit 2009 : Coordination Between Revit Structure & Revit building |
Fri, Jun 20, 2014 at 10:41:34 AM
