Forums >> Revit Building >> Technical Support >> rail to post connection
Tue, May 13, 2008 at 9:12:09 AM | rail to post connection
jarosa
jarosa Avatar
4 Stars: 5 Votes
I need a little help making the connections between the rail and the posts. I have two problems.
1. post at corner stops at bottom. In the field the post gets ground and welded to form a 3 way corner. ????
2. post on the right side needs to be set perpendicular to the end. There must be something really simple i'm missing but i tried using the offset in balluster placement without much luck.
 Thanks,
John
Wed, May 14, 2008 at 7:13:52 AM | rail to post connection
You might want to look at building an endpost that includes a portion of the rail.  Take a look at the handrail extensions that are available in the families here.  Although the extensions are "handrails", the are used in the "post" position.
Post and Rail Seam in Rev-it 2012
Tue, Feb 27, 2018 at 8:02:18 AM
balister/post color different form rail
Wed, May 11, 2011 at 11:08:51 PM
Non-Continuous Top Rail of a Railing Strucutre
Fri, Oct 5, 2018 at 3:24:00 AM
Baluster inside Newel Post revit 2014
Wed, Mar 26, 2014 at 2:54:06 AM
Stair Rail extending through Balister
Tue, Nov 20, 2007 at 3:59:06 PM
Page generation time: 1.6665
