32 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> demo wall schedule "by floor"
Thu, Mar 31, 2005 at 11:16:00 AM | demo wall schedule "by floor"
aabrmn
I am trying to set up a demo walls schedule. What is really hard to achieve for me is FILTERING BY FLOOR. In fact, while in the official training courseware book this looks very easy for windows schedule (...in the filter tab, you can choose Level as your filtering parameter and set its value to Level 3...) when I access the filter tab in the schedule properties dialog I do not get "Level" option in the "filter by" dropdown menu. That does not either appear in the available fields list in the fields tab of the same dialog window. I could not either find the Base Constraint parameter, which is the one that seems to be appropriate for walls. If I add the parameter Base Constraint this simply introduces another Base Constraint parameter to the wall object duplicating the existing one. This simply would not work. I am attaching a sample file for those who are gently willing to point me out of this unconvenient impasse. Thank you very much. Post edited on 2005-03-31 11:49:29 Post edited on 2005-03-31 11:50:08
Thu, Mar 31, 2005 at 9:50:52 PM | RE: demo wall schedule "by floor"
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hmm, i really i don't think this is possible by any automatic method. I'd imagine the only way would be to add a parameter for level and just enter it in manually. Certainly not automatic and could result in errors. If i find out any more i'll let you know, but doesn't look good.
Thu, Mar 31, 2005 at 11:19:28 PM | RE: demo wall schedule "by floor"
aabrmn
Thanks Mr Spot. No way to set a parameter to point to another one? like the goto command? Again, your advice is highly appreciated.
Fri, Apr 1, 2005 at 1:43:15 AM | RE: demo wall schedule "by floor"
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
No unfortunately there is no way to link to system parameters atm...
demo walls schedule
Wed, Mar 30, 2005 at 6:40:27 PM
Room/area tags on floor plan with demo'd wall
Tue, Feb 10, 2009 at 9:53:41 AM
Floor Demo
Fri, Mar 20, 2009 at 3:24:16 PM
demo wall
Tue, May 11, 2010 at 10:18:14 AM
wall schedule showing zero length for demo infill walls
Tue, May 11, 2010 at 1:37:18 PM
Page generation time: 2.2677
