Forums >> Revit Building >> Technical Support >> Cutting a Curtain Panel
Mon, May 12, 2008 at 1:25:20 PM | Cutting a Curtain Panel
hippy
How do I get Revit to cut the last panel of a wall using a detail component or a complex extrusion ie: a 20" corrugated panel. I have gone as far as using a void extrusion to hide the remaining pattern and a shared parameter to track the lengths of the pieces, but this is extreemely inefficient because I have to edit the last panel in every wall unless I luckup and one works out. There must be a better way.
Wed, May 14, 2008 at 7:18:14 AM | Cutting a Curtain Panel
? ? ? Question needs clarity.  Sketches ... ?
Wed, May 14, 2008 at 8:19:29 AM | Cutting a Curtain Panel
coreed
coreed Avatar
4 Stars: 16 Votes
also why are you providing a template file (.rte) ???
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Cutting a complex Curtain Wall Panel
Thu, Apr 17, 2014 at 9:44:49 AM
Curtain system panel problem
Tue, Jul 10, 2007 at 10:08:07 AM
curtain panel offset
Mon, Sep 1, 2014 at 4:30:14 PM
Curtain Wall Panel to Curtain Wall Door
curtain wall panel losses end - edge
Tue, Jul 15, 2014 at 7:04:22 PM
Page generation time: 0.3648
