20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Error in RAC 2009-RENDER
When i try to "Push" for Mental Ray with "custom-Settings" in High appears this Error, anybody knows why? Out-of-memory? what?
I have a Dual-Core2 2.4Ghz with 3Gb Ram, ATI Radeon 1600 512Mb XP professional, the settings of render are attached in this 3 images, i push to revit to see the best quality but...
if you dont have the 3 gb switch enabled Revit can only utilize 2 gb of your ram. the autodesk website support center gives you detailed instruction on how to enable it.
thanks "alabaster", i think i just do it a few time ago but i will check...
Be careful: I tried the /3Gb switch and had unbelievable display hassles - I played with other switches like /USERVA= and /PAE to try to get it to work better but got nowhere - There seemed to be problems with the RAM addresses that my video (256 Mb ATi FireGL 7200) card was using. Eventually replaced the machine with another and this one reports 3.25 Gb available with no switches enabled and seems to run just fine. Both machines are Dell dual-core 3 Ghz with 4Gb of RAM
Hi "MikeM" thanks for advise, but it's to late, i do that but XP don't recognize the 3Gb, i ask for my " hardware supplier" and he told me it maybe the new drivers from "Chipset" so i go to Asus site and actualise the drivers, but XP don't LIKE so i "Crash", my solution was install Vista 64Bits, backup all my folders format the disk and them i install the new drivers from "Chipset" to my motherboard... now i work with Vista 64 and i don't have no more that problem... i "push" from Revit mental ray and it's ok...
Adding New Materials to the Render Appearance Library in RAC 2009? [ 1 2 3 ] |
Fri, Aug 8, 2008 at 6:11:21 PM
31
Revit 2009 render error message |
Wed, Oct 15, 2008 at 3:04:06 PM
An error in RAC 2008 |
Sat, Dec 8, 2007 at 1:07:51 PM
Render Calculation Error? [ 1 2 ] |
Fri, Jun 7, 2013 at 7:53:38 AM
19
Render Error - "Unknown Error during Rendering Calculations" |
Fri, May 1, 2009 at 1:52:23 PM
