Forums >> Revit Building >> Technical Support >> How do I render a walkthrough? I can't find any settings
Mon, May 12, 2008 at 12:50:28 PM | How do I render a walkthrough? I can't find any settings
Caliber
I have a walkthrough of a building I want to render but don't know what the first thing is to do. I have already rendered still images of the model, but I assume with a lot of time you can render each scene as it walks through.
TThanks
Mon, May 12, 2008 at 1:17:34 PM | How do I render a walkthrough? I can't find any settings
TABEST
4 Stars: 4 Votes
Once you have your walkthrough as you want it, then go to file->export->Walkthrough, choose to render it here, and it should ask you which render settings to use... You said you already had some, so I assume you'd want to use those.  Don't go anywhere until after it render's the first frame, because it then asks what format you want to save the walkthrough as... .avi, etc.  Hope this helps.
Render a walkthrough?
Thu, Oct 3, 2013 at 8:42:11 AM
New to revit and have a question... Re: walkthrough on 2011
Tue, Apr 12, 2011 at 6:01:12 PM
render specific frames of a walk through
Fri, Oct 7, 2011 at 3:39:42 PM
Walkthrough on Render Setting Very Pixelated RVT '14
Wed, Oct 29, 2014 at 12:48:58 AM
Rendering a Walkthrough
Fri, May 5, 2006 at 9:42:55 AM
Page generation time: 0.7633
