Forums >> Revit Building >> Technical Support >> Artificial Lights DO NOT turn on in rendered scene
Mon, May 12, 2008 at 12:20:48 PM | Artificial Lights DO NOT turn on in rendered scene
Jzaid84
When I have the setting "Artificial and Sun" on, the only light I ever get is sun light. The artificial lights never get rendered. The only time I can get them to render is when I have "Artificial Only".
 Any ideasas to why this is happening? Please help, I have to get some drawings put out soon here.
Thanks,
Jimmy
Wed, May 14, 2008 at 1:37:20 AM | Artificial Lights DO NOT turn on in rendered scene
pattyceads
Hi, I'm having the same problem as above, any help would be good.
Cheers
Pattyceads
Wed, May 14, 2008 at 2:00:24 AM | Artificial Lights DO NOT turn on in rendered scene
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Artifical & Sun settings isn't really very well resolved at the moment from my experience.  The lights seem to put out very little light at all when the Sun is turned on.
You have two options,
Drastically increase the intensity of all your lights OR
Composite an Artificial Only + Artificial & Sun image together in Photoshop or Gimp and use the "difference" filter.
Regards,
Chris.
Wed, May 14, 2008 at 11:10:21 AM | Artificial Lights DO NOT turn on in rendered scene
mthurnauer
3 Stars: 2 Votes
I have not gotten into this yet in revit, but it is an issue that is common to many applications.  If exterior light is providing something in the area of 10,00fc and interior lights are providing around 60fc at the work plane, then their contribution is negligent.  Any attempt to make them both seem as if they contribute to the scene equally is probably faking things.  I have not looked, but can you adjust the sun intensity in revit?  If so, it would probably be easier to decrease the sun and sky intensity that increasing all of the interior lights.
Sat, May 31, 2008 at 7:20:20 PM | Artificial Lights DO NOT turn on in rendered scene
ginacang
4.5 Stars: 2 Votes
when you say increase the intensity of the lights... by how much? because I set my studio lights which were 6800 lms to 100,000.00 lm and my interior rendering is still not lit...
Sun, Jul 13, 2008 at 11:03:42 PM | Artificial Lights DO NOT turn on in rendered scene
shaun_kiwi
5 Stars: 2 Votes
We are having all of these problems with balancing the lights. We shoot a render with artificial lights only and play until it is about right(not all that happy yet) then he who must be obeyed decides the sun should be on in this view and I have to increase the light levels 150 times to get near where we should be at. I find Mental rat very tricky for interior renders. Not a complaint about exterior views but my guess is that it is not intended for interiors yet. I used to use lightscape years ago. My memory of it was it was much easier to use and better results than mentalray for interiors.
Shaun
Tue, Aug 12, 2008 at 1:41:16 AM | Artificial Lights DO NOT turn on in rendered scene
vicozzio
So, until now, there's no solution yet to this problem? because I got the same problem, even the sun and shadow setting I arrange at 12 PM (at midnight), the artifical lighting still not turned on.
Tue, Aug 12, 2008 at 3:44:07 AM | Artificial Lights DO NOT turn on in rendered scene
chiragpklg
4 Stars: 11 Votes
Hey guys do you mean sumthing like wht I have attached to this post please go through it & even the settings & do reply me whether i m right or not
Chirag C. Pawar
Cad Solution Application Senior Engineer
KLGSystel Ltd. India
301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel    .:    +91 22 409 16777. Extn. - 718Fax   .:    +91 22 275 76461.Mob  .:   +91 99 698 66851.Email.:    chiragp@klgsystel.com
Web  .:    www.klgsystel.com
Tue, Aug 12, 2008 at 4:18:37 AM | Artificial Lights DO NOT turn on in rendered scene
4 Stars: 205 Votes
Hi, do you turn on the "Daylights"?
Tue, Aug 12, 2008 at 4:22:32 AM | Artificial Lights DO NOT turn on in rendered scene
chiragpklg
4 Stars: 11 Votes
Ya the "Daylight" is on.
Chirag C. Pawar
Tue, Aug 12, 2008 at 4:34:02 AM | Artificial Lights DO NOT turn on in rendered scene
#11
4 Stars: 205 Votes
Hi CHIRA, i was asking to VICOZZIO...
Tue, Aug 12, 2008 at 7:12:39 AM | Artificial Lights DO NOT turn on in rendered scene
#12
vicozzio
Hi Typhoon, do you mean by daylight is the sun & shadow setting? if it is, Yes, I think the option is only to use sun only, combine sun and artificial and artificial only, right?
Now, the problem is the combine option, that the thread starter (Jzaid84) and I'm facing... that the render result is too dark.. even the dim of all lights is 1. and if I use the artificial only, I can get the bright result of the artificial lighting. so much different from the combination option.
Chiragpklg, I never try interior perspective view to use this combination lighting option before, mabe I'll try later.. currently I'm still busy modelling, after this project done, I'll try to attach my render result about this lighting problem...
Tue, Aug 12, 2008 at 8:13:07 AM | Artificial Lights DO NOT turn on in rendered scene
#13
4 Stars: 205 Votes
Hi VICOZZIO, did you upgrade your revit 2009 with (SP) Web Update..... 1900? with this kind of Service Pack they fix very issues in Revit and lights/render are one of them, so...
Tue, Aug 12, 2008 at 2:51:34 PM | Artificial Lights DO NOT turn on in rendered scene
#14
4 Stars: 205 Votes
After Render i just change some values in "Adjust Exposure"...
Tue, Aug 12, 2008 at 4:26:32 PM | Artificial Lights DO NOT turn on in rendered scene
#15
shaun_kiwi
5 Stars: 2 Votes
In my experience if you have to adjust exposure drastically you are doing something wrong. We have had pretty good results from increasing the artificial light levels to 250-350 watts and being careful about how many light sources are considered by revit in the model. We have also rebuilt our lights to better suit Revit 2009. There is all the advice you need right here in revitcity. There is one particularly good thread on file size and rendering but I sorry I cannot remeber where. See attached file.
Shaun
lighting scheme and artificial lights
Mon, May 19, 2008 at 9:21:47 PM
Revit 2009 interior rendering isue
Wed, Sep 3, 2008 at 1:52:28 PM
Revit 2009 - interior rendering with exterior sun and artificial lights
Fri, Oct 10, 2008 at 10:25:18 AM
External Lighting Night Scene
Mon, Oct 26, 2009 at 2:09:22 AM
Revit always renders all of the lights
Fri, Aug 8, 2014 at 9:24:36 AM
Page generation time: 0.1784
