Forums >> Revit Building >> Technical Support >> daylight portals
Mon, May 12, 2008 at 10:17:10 AM | daylight portals
THG2005
1 Stars: 1 Votes
In Revit 2009, how do i turn on daylight portals?
Mon, May 12, 2008 at 10:23:12 AM | daylight portals
THG2005
1 Stars: 1 Votes
nevermind i found it
Tue, May 13, 2008 at 7:30:24 AM | daylight portals
chiragpklg
4 Stars: 11 Votes
where do u find it just let us know
Chirag C. Pawar
Cad Solution Application Senior Engineer
KLGSystel Ltd. India
301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel    .:    +91 22 409 16777. Extn. - 718Fax   .:    +91 22 275 76461.Mob  .:   +91 99 698 66851.Email.:    chiragp@klgsystel.com
Web  .:    www.klgsystel.com
Tue, May 13, 2008 at 8:54:47 AM | daylight portals
Thread Post Kudo! #4
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
In the rendering dialog there is a pulldown for the QUALITY, set that to edit and in the RENDER QUALITY SETTINGS dialog check the boxes for the daylight portals you want Revit to read. You have three choices to pick: doors, windows and curtain walls. Just check those and Revit will do the rest.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Tue, May 13, 2008 at 8:56:42 AM | daylight portals
brettgoodchild
4 Stars: 17 Votes
I should also mention that there is a pulldown on the top of the render quality dialog that you will need to set to custom to allow you to change the settings.
                             ~ Abraham Lincoln
Wed, May 14, 2008 at 12:03:01 AM | daylight portals
chiragpklg
4 Stars: 11 Votes
thanx 4 the reply brettgoodchild
Chirag C. Pawar
Can you limit Daylight Portals?
Mon, May 17, 2010 at 1:50:07 PM
Daylight Portals Rendering
Mon, Jun 24, 2013 at 7:36:12 AM
Daylight Portals
Tue, Jan 10, 2012 at 9:34:21 AM
daylight portals 0
Mon, Nov 25, 2013 at 11:59:51 PM
day light portals
Tue, Aug 23, 2011 at 7:09:13 PM
Page generation time: 1.4748
