31 Users Online (29 Members):
Forums >> Revit Building >> Technical Support >> Level lines on sheets...
42 Posts No Rating |
RAC 2008 Hi all. I work in the residential design field, and when we print our plans, we place two elevations on each sheet; for example, we will place the front and left side elevations on one sheet and the rear and right side elevations on the other. We show them at a scale of 1/4"=1'-0" for easier legibility. I am having some trouble with my level lines. It seems that if I change them in one view, then try to change them in another, corresponding view (left and right side elevs., for example), the first view updates. Can I adjust the level lines for individual use on the sheets or do I need to use detail lines? Need some input please? I hope I'm not too vague in my question, but if I am, let me know and I will try to clear it up some. Thanks. Jim H.
When you click on a level line or a column grid, you will see a 3d that turns on - on the locator line. Click on that to change it to 2D and now you can independently drag your level indicators.
Thanks for the quick response. That's pretty cool.
split level homes |
Tue, Feb 17, 2004 at 7:04:24 AM
Level Lines missing |
Fri, Sep 26, 2014 at 8:09:18 AM
sections and level lines |
Wed, Jul 12, 2006 at 4:39:50 PM
Level Lines |
Mon, Nov 19, 2012 at 9:46:59 AM
I have new elevation views in a second building but want the level lines to show |
Wed, Jul 25, 2012 at 7:22:45 AM
