Forums >> Revit Building >> Technical Support >> RENERING 2009 ???
Sun, May 11, 2008 at 6:56:26 PM | RENERING 2009 ???
DESIGN4BUILDING
DESIGN4BUILDING Avatar
3.5 Stars: 3 Votes
i downloaded  Revit 2009 trial from autodesk and got a first peek at the sofeware. the first thing i did was get and old job from v.2008 and picked a view to render. i must be doing someting wrong !!! what happen to reytrace, my rendering came out very bad and i mean bed. what am i diong wrong. i no it a lot to cover, but can someone tell me that their is hope.
Mon, May 12, 2008 at 4:35:45 AM | RENERING 2009 ???
4 Stars: 205 Votes
Hi, when you click in Render menu you have the choise tho change the "Quality" (draft, low, medium, high, best and custom the parameters), the raytrace option that's no longer valid, but you can "Tell" them if you have exterior light only or interior and so one.
Tue, May 13, 2008 at 7:26:32 AM | RENERING 2009 ???
mthurnauer
3 Stars: 2 Votes
Prior to 2009 I did not think that the rendering in Revit was worth using b/c I could get far better results in other programs in much less time.  II would like to give the rendering in 2009 a test spin and I wanted to know what some people's practices are regarding rendering.  Do you save a detached copy of the project file so that you can strip out uneccesary model content?  do you use clip planes to reduce the 'visible' portion of the model?  Any advice would be appreciated.
Tue, May 13, 2008 at 9:11:15 AM | RENERING 2009 ???
DESIGN4BUILDING
3.5 Stars: 3 Votes
i just use camrea view and go to the settings for sun and lights. i render it in draft or med. about 5 times to see if i got the lighting right, the if it looks good ill render it in presintation mode. talks about 30 min. looks good for me. you can check my uploads, i do ok. but im useing the down load v. 2009 trial and when i render it comes out really bad. you cant even see it. scramble eggs. also the download of revit struc. dose the same. iv tried 2 comp. no good. ill see if i can get a disc, maybe it will help or go talk to a reseller..... thanks
Tue, May 13, 2008 at 2:40:55 PM | RENERING 2009 ???
JustinT
I have to say I love the new Mental Ray engine. There are some issue with 2008 projects where not all your materials come over and you have to re-apply, but overall this is a major step forward.
Here's a link to some more info on the rendering: http://www.revitup.co.za/main/page_home_2009_guide_revit_goes_mental.html
It explains about the new Pro Materials, RPC and lighting in Revit.
Here's an image I rendered from an Autodesk model they showed at Tech Camp this year... it took 4 hours on maximum quality... 1/2 that on medium.
There is also the new export format FXB: http://www.revitup.co.za/main/page_news__articles_3ds_max_design.html
allowing you to export to MAX and have your model come in with all the materials, lights and cameras from Revit.
The only thing we have lost is the ability to create Panoramic files directly in Revit and also apply a background image (unless I have missed something)
Justin
www.revitup.co.za
Tue, May 13, 2008 at 2:58:59 PM | JustinT
NKramer
4 Stars: 9 Votes
Quoting JustinT from 2008-05-13 14:40:55
"The only thing we have lost is the ability to create Panoramic files directly in Revit and also apply a background image (unless I have missed something)
Justin"
R09 exports the background as an alpha chanel (read layer) so you can swap it out in photoshop or some other photgraphic editing program.
Nick
Edited on: Tue, May 13, 2008 at 2:59:36 PM
Edited on: Tue, May 13, 2008 at 3:00:02 PM
Tue, May 13, 2008 at 6:31:24 PM | RENERING 2009 ???
DESIGN4BUILDING
3.5 Stars: 3 Votes
thanks for letting me know about the 2008 to 2009 prob. that might be my prob. i hope !! i just got the trial v. and its doing the same thing, mabe my graphic card is not supporting mental ray or somthing.( need advice).  ill try to start a new project to see what happens.
Tue, May 13, 2008 at 8:22:43 PM | RENERING 2009 ???
DESIGN4BUILDING
3.5 Stars: 3 Votes
STOP THE 911  JUSTIN T  was right.  my 2008 drawing did not work with 2009 in rendering.. i tried a new project and worked great.... thanks everyone
Sun, May 18, 2008 at 5:44:40 AM | RENERING 2009 ???
Jaybo
4 Stars: 5 Votes
I found that if you change the settings from screen to printer 300 dpi is good quality. I think the screen settings come out worse for some reason but i still click best settings. not sure but the printer 300 dpi is what i leave it on
Sun, May 18, 2008 at 6:37:22 AM | RENERING 2009 ???
torstenk
Anyone know why my interior lights dont work?
If i set it to "sun and artificial lights" the artificial lights dont work. If i set it to "Artificial lights only" they work. See images
Sun, May 18, 2008 at 6:41:15 AM | RENERING 2009 ???
#11
Jaybo
4 Stars: 5 Votes
yeh i ahd the same problem Sad
Sun, May 18, 2008 at 8:10:57 AM | RENERING 2009 ???
#12
4 Stars: 205 Votes
I think there are some issues with this new version, the lights are one of them, i don't know if there is (yet) a Service Pack to 2009, i can't find anythink in Autodesk site...
Edited on: Sun, May 18, 2008 at 12:02:48 PM
Stretched view after renering
Tue, Sep 4, 2012 at 8:18:18 AM
interior 3d renerings
Tue, Feb 14, 2006 at 11:21:50 AM
Installed RA 2009 and RMEP 2009 Today
Tue, Oct 28, 2008 at 3:41:42 PM
Saving frpom 2010 to 2009
Wed, Jul 13, 2011 at 2:13:05 PM
Rendering in Revit 2009 [ 1 2 ]
Thu, Dec 31, 2009 at 10:41:31 AM
19
Page generation time: 1.9527
