Forums >> Revit Building >> Technical Support >> Stair break line (Revit 2008)
Sun, May 11, 2008 at 5:35:42 PM | Stair break line (Revit 2008)
niro
how do you turn off the stair break line?  I want to show an enlarged stair plan referenced from a floor plan at small size.  I tried VV/VG to modify all the cut line beyond to solid lines, it was staight forward.  But when I tried Line work to make the break line invisible lines, it was not pickable.  I later tried View range, but it seemed like i have to couple it with a few Plan Regions to show/not show stuff around the stairs...
can anyone understand what I am asking shed some light?
Mon, May 12, 2008 at 7:43:21 AM | Stair break line (Revit 2008)
I think what you are asking for can be accomplished by defining a plan reagion around your stairs.  Using plan regions, you can define a different cut plane that will not cut your stairs.  Chek its use out in your help menu.
Stair Break Line Customization
Mon, Dec 12, 2011 at 4:20:09 AM
Stair break line problem
Fri, Jul 17, 2020 at 4:21:45 PM
Can't modify (or switch) stair cut line/break line
Wed, May 11, 2016 at 10:58:08 AM
Break Line & Weld sybol families
Wed, Apr 28, 2010 at 9:18:41 PM
Stair Cut Line : Double Line
Mon, May 18, 2015 at 3:19:08 AM
Page generation time: 1.4939
