Forums >> Community >> Newbies >> Columns
Sun, May 11, 2008 at 8:03:43 AM | Columns
degs516
Ok im very new to revit ...but
i was wondering what is the difference between columns in the modeling design bar as apposed to the columns in the structural design bar
ive been modeling this model with the modeling design bar and i hope i shoulnt have been using the structural
Sun, May 11, 2008 at 8:15:45 AM | Columns
4 Stars: 205 Votes
Hi, the diference beetween this 2 columns is: the first it's automatically adjust to the wall of your model, in plan view you can see (in medium or fine mode) the materials of wall "involves" the column, but, if you insert the second column (structural) in the wall you can see the material of column and not the wall material around the column.
hidden columns
Fri, Mar 26, 2010 at 10:53:36 AM
Showing columns from the floor above
Mon, Jun 9, 2008 at 1:49:48 PM
recalcitrant columns
Tue, Aug 3, 2004 at 7:38:46 PM
Leaning columns
Sat, Jul 2, 2011 at 7:56:56 AM
Cut Pattern - Timber Columns in plan views to black ?
Tue, Mar 18, 2014 at 7:41:46 PM
Page generation time: 0.4476
