Forums >> Community >> The Studio >> Curtain Wall modify
Sat, May 10, 2008 at 3:01:08 PM | Curtain Wall modify
greg2311
The current curtain wall for storefronts has certain adjustments that I am not sure will allow me to adjust the outside vertical mullions to 4" apart from the other mullions. I have looked to see if there is a family/component that I can download, but found nothing. Is there a solution other than having to draw one from scratch? Also, I started to build one from scratch, but found that there were too many constraints when trying to flex the system. I feel like I have hit a wall with this, because I have not progressed further from this system before moving on to other systems in the building.
Mon, May 12, 2008 at 7:51:19 AM | Curtain Wall modify
I'm not sure what you are asking.  If you are wanting to move these mullions out from the centerline in plan, you can always create a new mullion definition that has a different offset then the others.  Just select the mullion - under properties, create a new one - name it and set the offset to what you want.
Mon, May 12, 2008 at 8:12:22 AM | Curtain Wall modify
greg2311
the vertical mullions at ends need to be 4", which is different from the other mullions, at 2". How do I achieve that?
Mon, May 12, 2008 at 9:18:00 AM | Curtain Wall modify
Pick them and change them to 4" mullions!
Modify Curtain wall Profil
Thu, Jan 4, 2018 at 4:34:23 AM
curtain system
Mon, Mar 3, 2014 at 12:28:25 PM
Using Edit Profile to Modify Curtain Wall Elevation
Mon, Nov 8, 2010 at 12:08:55 PM
problems with curtain walls
Fri, Apr 25, 2008 at 9:10:19 AM
lattices in curtain wall
Tue, May 26, 2015 at 8:39:46 AM
Page generation time: 2.1496
