Forums >> Revit Building >> Technical Support >> Can I change the color of the Default Wall?
Sat, May 10, 2008 at 2:03:34 PM | Can I change the color of the Default Wall?
alc112
Hi!
Is it possible to hange that grey color?
How? can you give a link to a tutorial?
I want to change the gray of these walls
Sat, May 10, 2008 at 2:38:31 PM | Can I change the color of the Default Wall?
4 Stars: 205 Votes
Hi, this is not a RENDER? is it?
First of all, when you create your wall type you have the choise to choose the color in "Model" , pattern in "Cut..." and "Texture.." to Render, so, if you do that, the image in attached it's Ok, isn'it?
I don't no what version of Revit are you work, (are the same equals, more or less),  but when you create (in this case) wall you must do that (color, cut and texture...) then when you put to Render the color and Texture of your model come "Right", i think you must review the materials of your walls (windows and so one) before render.
Yes, this is a critical, but i hope you understand for a "CONSTRUCTIVE CRITICAL", try "help menu" AND try this sites:
-  http://revitzone.com
-  http://www.revitup.co.za
Good luck
Be Positive...
Sat, May 10, 2008 at 6:46:54 PM | Can I change the color of the Default Wall?
alc112
That image is indeed a Render.
I'm very noob! all know of Revit I learned it thanks to some video tutorials I found in Spanish. It's a bit hard for me to understand spoken english.
Now, with those new concepts you gave I'll keep on researching.
Thanks a lot
Sun, May 11, 2008 at 4:18:11 AM | Can I change the color of the Default Wall?
4 Stars: 205 Votes
He visto tu perfil y no está tu nacionalidad, no sabia k eres español o pelo menos k hablas espanhol, tienes k lebar esto como una critica POSITIBA, si no sabes hablar "bien" el ingles es un poco dificil aprenderes el Revit (yo soy portugues e espero que estea a escribir "Minimamente" el español), en el You Tube tienes buenos tutoriales pêro estan en ingles y ai unos muy buenos em portugues (brasileros), tienes la ayuda de Revit para todo lo k hagas, no se si hablas portugues, si tienes alguna duvida en especifico puedes hablar (escribir) en español k yo te respondo (tienes mi Email en mi profile)...
Sun, May 11, 2008 at 11:13:16 AM | Can I change the color of the Default Wall?
alc112
Soy Argentino. Yo sé inglés, bastante. Sólo que no soy muy bueno entendiendo el inglés hablado, pero sí el escrito.
POr suerte ya pude resolver el problema. Tuve que reinstalar el Revit. Ahora sí aparecen los materiales.
I'm Argentine. I know quite a lot of English but I'm not so good at listienig comprehension, but I am at written.
Luckily, I could solve the problem but I had to re-install Revit. Now I can see the Materials.
Fri, May 4, 2012 at 11:36:17 AM | Can I change the color of the Default Wall?
Filipe1234
Yo sou portugues tambien!
how to change the default ground color ?
Thu, Feb 26, 2009 at 8:24:47 PM
2011 change material color [ 1 2 ]
Sat, Aug 31, 2013 at 8:46:22 AM
16
How to change Revit Color Fill Legend default text - "No colors defined"?
Sat, Oct 26, 2024 at 9:27:44 AM
massing - default color not visible
Tue, Jun 9, 2009 at 9:28:37 AM
Revit 2010 default highlight selection color
Fri, May 8, 2009 at 5:11:01 PM
Page generation time: 2.7453
