Forums >> Revit Building >> Technical Support >> Non-Bearing Walls Visible in Structural View
Fri, May 9, 2008 at 10:54:39 AM | Non-Bearing Walls Visible in Structural View
YoKanski
I was wondering if there was a way to see Non-bearing walls in a Structural view?
Wed, Jul 9, 2008 at 9:02:23 AM | Non-Bearing Walls Visible in Structural View
pdoug
3 Stars: 2 Votes
I too would love to know how to make a non-bearing wall show up in a structural view.  The discipline for the view is set to structural and I have (technically) non-bearing masonry walls I need to have show up in plan, but they do not unless I change their structural usage.  Is this possible?  and if not, what good is it to have this as an option if you can only make it visible if you change the discipline?
 Thanks for the help!
Wed, Jul 9, 2008 at 9:52:20 AM | Non-Bearing Walls Visible in Structural View
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
I assume that changing the view from Structural to Coordination doesn't get you where you want to be?
Wed, Jul 9, 2008 at 9:58:06 AM | Non-Bearing Walls Visible in Structural View
pdoug
3 Stars: 2 Votes
Coordination may be a "work-a-round" similar to switching to architectural, but it doesn't answer the question on whether it is impossible in Revit Structure to have non-bearing walls show up in a structural view.
Wed, Jul 9, 2008 at 10:07:55 AM | Non-Bearing Walls Visible in Structural View
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
In our office, the structural guys just have us turn any wall they want to show up to be load-bearing and any wall they don't want to show up as non. If I remember right, they tried for a while to do what you are trying and weren't successful....which doesn't mean that it's not possible, but I trust the results enough to take my time to set all of my (architectural) walls to whatever they request.
Wed, Jul 9, 2008 at 10:10:45 AM | Non-Bearing Walls Visible in Structural View
pdoug
3 Stars: 2 Votes
Wed, Jul 9, 2008 at 10:13:38 AM | Non-Bearing Walls Visible in Structural View
pdoug
3 Stars: 2 Votes
Didn't intend to reply the same message twice - not sure what happened there.  I understand where you're coming from and appreciate the info.  I will have to (for the time being) do the same as you describe as that is the easiest way around it right now that I can think of.
Anyone else hear or know more updated information regarding this topic please respond - your replies are helpful, thanks-
pdoug
Tue, Jan 13, 2009 at 5:34:49 PM | Non-Bearing Walls Visible in Structural View
structuresguy
I would sure like to be able to do this, as I want to schedule my walls and have the structural usage field in my wall schedule show "bearing" or "non-bearing"  When I switch it to architectural view, my section cuts disappear.
Bearing vs. Non-bearing walls
Wed, Oct 10, 2012 at 3:04:30 PM
i need to show colums, bearing walls and primary structural grids in my revit..
Mon, Mar 31, 2014 at 7:57:09 AM
Exterior Bearing Walls?
Tue, Jan 22, 2008 at 8:46:40 AM
Plan region/bearing walls
Mon, Jan 21, 2008 at 12:14:19 AM
Openings in (Structural) Walls Scheduling as Non-Bearing Walls
Thu, Feb 21, 2008 at 5:55:28 PM
Page generation time: 2.5957
