11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Raised floor
12 Posts No Rating |
Hi, I am working on a project and have to make a raised floor with a clearance of 200mm below the floor for the lighting. Please help fast i don't know how to make raised floors.
Use the floor tool and define the boundary of the raised portion of the floor. Then set the Offset from Level to the Height. I usually draw wall type objects to represent the upright supports around the edge of the raised floor. I then use Join Geometry to make sure there is no unwanted lines showing around the edge. I know this is kind of vague, but it is the general Idea.
Thanks! I add the floor(165mm) by seting the offset of 200mm as i want a clearance of 200mm below the floor for electrical lighting. Now, to define the clearance area of 200mm what should i do?
I'm not really sure what you mean by "Clearance Below the floor." Could you maybe post a screenshot of what you are trying to do or maybe explain in depth.
here is the screenshot attached. The dimesion written as 165 is the raised floor and i am not able to figure how does i will show the rest of the area below the floor. I hope the screenshot works.
Dear,
this is really a bit difficult, and i shared a pic of instruction for you to install the raised floor.
hope it may be helpful to you.
Best Regards,
Vivian
Edited on: Wed, Jun 24, 2015 at 7:17:56 AM
Raised floor system |
Thu, Jun 25, 2015 at 2:10:09 AM
raised floor |
Tue, Jun 23, 2015 at 4:35:05 AM
Creating Raised Floor systems |
Thu, Nov 13, 2008 at 11:49:31 AM
Raised Computer Floor |
Thu, Jun 25, 2015 at 10:33:28 PM
Tiered Raised Access Floor - Revit 2013 |
Thu, May 9, 2013 at 7:55:28 AM
