16 Users Online (14 Members):
Forums >> Revit Structure >> Technical Support >> SPLITTING WALL PANELS REVIT STRUCTURE 2009
Hello, I am a Revit Structure Newbie in the Vancovuer BC Area. I have been Given as a first project a Square Tilt-up Building. As some of you are aware Tilt-up Construction consist of Concrete Panels casted flat on a slab and tilted up into place. I am trying to represent Each Panel as a single Entity. I created a new type of wall, and I drew the outline of the building with it. then I tryed to Split the wall where Panel Joint are supposed to happen. a Panel Joint is only 3/4" wide. I used the split tool to try to achive a 3/4" gap, but the wall kept on joining itself back again and again. Can anyone tell me if there is a setting I need to change for this not to happen? or if you know another wy to achive this? I tried doing a full height opening as well but the wall remain as one entity instead of several panels. Thank you kindly in advance. Vanrevit
Welcome to the REvitlution!!! |
to keep the wall from joining, select the wall - right click over the blue dot at the end of the wall and select Disallow join
Thank you kindly for the response
Splitting a wall with a Reveal |
Fri, Feb 19, 2010 at 11:25:44 AM
Can't delete Glazing or System panels in Revit Structure |
Wed, Apr 17, 2013 at 9:57:51 AM
Trussed structure, screen panels.. |
Tue, Jul 1, 2014 at 12:15:24 PM
Rendering in Revit Structure 2009? |
Sat, Dec 24, 2016 at 5:11:53 AM
curved wall panels |
Sun, Jul 18, 2010 at 9:26:46 AM
