9 Users Online (7 Members):
Forums >> Community >> Newbies >> Hello I Am New To Revit and need a question answered.
Hello, I am a Revit Structure Newbie in the Vancovuer BC Area. I have been Given as a first project a Square Tilt-up Building. As some of you are aware Tilt-up Construction consist of Concrete Panels casted flat on a slab and tilted up into place. I am trying to represent Each Panel as a single Entity. I created a new type of wall, and I drew the outline of the building with it. then I tryed to Split the wall where Panel Joint are supposed to happen. a Panel Joint is only 3/4" wide. I used the split tool to try to achive a 3/4" gap, but the wall kept on joining itself back again and again. Can anyone tell me if there is a setting I need to change for this not to happen? or if you know another wy to achive this? I tried doing a full height opening as well but the wall remain as one entity instead of several panels. Thank you kindly in advance. Vanrevit
Welcome to the REvitlution!!! |
to keep the wall from joining, select the wall - right click over the blue dot at the end of the wall and select Disallow join
Thank you kindly for the response.
Have you considered making these as a custom component, that you can then array into place? Regards, Ian
www.RevitZone.com News / Articles / Tutorials / Forums / Beginners Guide to Revit |
I have considered it, but Panels can be all kinds of differente sizes within oone wall. hen there is adding openings and editing the shape of the panel (ie. If the panel top is sloped or if it has a weird shape. Cheers! Vanrevit
You could add parameters to control all the variables you mention (overall size, opening or not, sloped top) This would then allow you to schedule all your panel types. Just a thought! Cheers, Ian
REVIT ANSWERS DIRECTLY |
Mon, Jul 30, 2007 at 11:22:19 PM
Rounding in Formulas |
Wed, Mar 13, 2013 at 8:25:55 AM
tEXT jUSTIFICATION |
Wed, Jun 20, 2018 at 11:10:09 AM
It is a really slow day on revitcity |
Tue, May 26, 2009 at 8:38:23 AM
14
Sloping Bar Joists? |
Thu, May 7, 2009 at 9:41:08 AM
