25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> area plans & schedules help
3 Posts No Rating |
We need to produce area schedules that not only show the area. For approval, we have to break down the areas into discrete boxes that a plan examiner multiply out the dimensions of to verify the individual areas, then add all of those up to verify the total area. yes its a royal pain. So we need area schedules to show also the dimensions of boxes that we create and then multiply out those dimensions to get an area (this is due to the rounding errors created by the differences between the numbers examiners get by doing the multiplication and the numbers that revit returns as areas). We have tried a couple of different approaches, but there is always something that doesn't quite work. Are there any suggestions?
3 Posts No Rating |
incidently this is revit 2008 we are currently working on. we have 2009 but have not installed it yet.
3 Posts No Rating |
bump. if anyone is interested, we have finally worked out a way to do this that seems to work pretty well. we can't quite get the schedules to do everything we want, but we accomplished 90% of what we needed. if you want to know how, i can post a brief description of our approach.
I would be interseted in knowing how you did this
hey i have the same question . can i know how its done . i too am looking for developing ways in which i can make calculations in schedules.
Area Plans & Room Tags |
Fri, May 12, 2006 at 3:50:55 AM
Area Schedules and Area Schemes - Revit 2019 |
Tue, Apr 2, 2019 at 7:41:56 AM
Area Schedules showing Metric and Imperial |
Thu, May 28, 2009 at 11:49:29 AM
Combining Room Schedules and Area Schedules into one Large Schedule |
Thu, Jan 3, 2013 at 10:57:33 AM
new Area Scheme question |
Tue, Jun 20, 2017 at 4:11:49 PM
