Forums >> Revit Building >> Technical Support >> Creating parameter
Wed, Mar 30, 2005 at 11:31:00 PM | Creating parameter
justinmthomas2003
I'm trying to figure out how one parameter name was connected directly to plant library where all plants are... also I want to create plants that I need for my project .. b/c not all plants are in library... do anyone know how to do explain that to me? I want to make my own plant ... create my own symbol of the plant for floor plan .. then create isometric plant and raytace it... I m having hard time understanding how to create parameter.. right now I'm new with that part. ..hopefully some of you know what I m asking for..
Thu, Mar 31, 2005 at 1:52:59 AM | RE: Creating parameter
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use the Planting template file in Revit. Then basically model or draw how you want your plant to show in Hidden and Shaded View elevations and plans. That's the easy part. The hard part is trying to create a new plant in accurender for the rendering side of things. I haven't had much success with this and it would be best trying to make use of one that is already there. Maybe there is an avid accurender user outhere who can explain this side better...
Creating Uneditable Parameter?
Wed, Mar 12, 2014 at 12:50:31 PM
Creating Y/N Parameter
Wed, Dec 23, 2015 at 8:08:37 AM
CREATING NEW LABEL PARAMETER FOR TITLE BLOCK
Fri, Jun 9, 2006 at 12:16:03 PM
HELP.....Creating a 2d bed family
Mon, Feb 1, 2010 at 4:04:52 PM
How do you share a parameter between several different sheets?
Thu, Nov 10, 2016 at 3:15:54 PM
Page generation time: 2.5859
