Forums >> Community >> Newbies >> Thick walls
Wed, May 7, 2008 at 7:24:07 PM | Thick walls
renatolemus
Hi: In my company we usually design a kind of very massive architecture, with thick walls and thick openings on them.My question is what is the best approach for this kind of modelling in revit. Should I create double 150mm walls, as in the example, and then a concrete beam, and then the 2 walls segments over the beam, then changing the material with the paint tool? or should I create a new type of wall with a air layer in the core?.  And the last question is, how can I place a door in this already created thick opening?. Is there any parameter to prevent the door from using the full thickness of the wall to create the frame, I mean to set a fixed depth for the framing. (I don't want the frame covering the full thickness of the opening).
check my attachments
thanks in advance.
Wed, May 7, 2008 at 9:25:28 PM | Thick walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You'll probably find it easier to do as a single wall with the appropriate wrapping properties at openings.
as for the door, yes its possible to create a door with a frame that is not associated the wall thickness.  Just don't constrain it to the wall faces and give the frame a depth and offset parameter so you can position it appropriately in the wall.
HTH.
Regards,
Chris.
Thu, May 8, 2008 at 12:00:29 AM | Thick walls
renatolemus
Thanks a lot Chris, about the door, you mean, when making a new door family? or in the door instance creation parameters?
Window reveals in thick stone walls
Tue, Nov 9, 2010 at 12:30:00 PM
Wall Joins at ends of uneven width walls
Tue, Sep 18, 2007 at 2:00:21 PM
Doors in thick walls
Mon, May 4, 2009 at 6:14:44 AM
Scheduling Compound Walls
Wed, Nov 30, 2005 at 7:05:54 AM
Thick Datum Line appearing in sections only???
Fri, Aug 9, 2013 at 7:27:48 AM
Page generation time: 1.3769
