Forums >> Revit Building >> Technical Support >> imported sketch up model and view range only sees roof>
Wed, May 7, 2008 at 7:15:31 PM | imported sketch up model and view range only sees roof>
ecocollaborative
I imported a sketch up model and the view range is set to level 1  0'-0" elevation with top at 7' and cut at 4' yet i only see the roof?
in the ceiling plan it shows the the walls and the furniture?
I need to see the walls below the roof to create the revit model?  whats going on?  I made adjustements in view range and nothing seems to work.  when i go to elevations everything looks right.  also when i cut sections it only shows me the corresponding elevation and not an actual section>
help
Wed, May 7, 2008 at 9:28:12 PM | imported sketch up model and view range only sees roof>
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Import it into mass familiy first, imported skp or dwg files do not get cut by sections or plan cuts.  You can see that information in the RCP because you sketchup model has no floor.
Regards,
Chris.
Wed, May 7, 2008 at 9:33:09 PM | imported sketch up model and view range only sees roof>
ecocollaborative
not sure how to import into mass family?
Wed, May 7, 2008 at 9:38:25 PM | imported sketch up model and view range only sees roof>
ecocollaborative
excellent
that totally worked
via mass family it recognizes all the info
View range and floors
Fri, Aug 19, 2011 at 4:55:36 PM
Linked Model View Range Issue
Mon, Mar 17, 2014 at 3:59:53 PM
Revit Roof View Range - Revit 2013
Wed, May 8, 2013 at 8:22:41 AM
Help - Sketch Up Models are hidden!?
Tue, Dec 7, 2010 at 10:35:46 AM
view range of a link file
Wed, Jul 30, 2008 at 3:51:37 AM
Page generation time: 4.8888
