Forums >> Revit Structure >> Technical Support >> Steel Beam spot elevation
Wed, May 7, 2008 at 6:26:17 PM | Steel Beam spot elevation
Marmar
I need to show the elevation of each of my beams in a plan view. They are attached to a sloped slab, and I need to show the top of steel on all of them.
Is there a way of using the spot elevation tool or something else to make it parametrical?
Top of Steel / Bottom of Deck Elevation using a Spot Elevation?
Fri, Jan 21, 2011 at 2:04:46 PM
Beam Tag with Top of Steel Elevation ?
Fri, Aug 1, 2014 at 8:12:42 AM
Quickly See Beam Top of Steel Elevation
Thu, Oct 16, 2014 at 10:51:52 AM
Spot Elevation
Thu, Apr 28, 2011 at 3:46:55 PM
Steel beam views
Fri, Apr 1, 2016 at 3:08:27 PM
Page generation time: 2.2289
