Forums >> Revit Building >> Technical Support >> Finding and Replacing Text
Wed, May 7, 2008 at 2:45:43 PM | Finding and Replacing Text
revitcitydownloads
Is there a command in Revit similar to Autocad where you can find and replace text?
Wed, May 7, 2008 at 5:43:39 PM | Finding and Replacing Text
lab21
REVIT dosen't have a find replace utility (Haven't been brave enough to try 2009 yet), but there are some clever people out there who have done somthing about it. I can't remember where I found this. Works for REVIT 2008, read the .txt file to install. Once done you'll have 'Find replace' under 'Tools - External tools'
 HTH
Luke
Edited on: Mon, May 12, 2008 at 8:52:23 PM
Edited on: Mon, May 12, 2008 at 8:52:52 PM
Wed, May 7, 2008 at 9:40:23 PM | Finding and Replacing Text
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you install the VSTA add on, which is the built in Revit API script writer, I believe there is a sample script for this that you could use.
Regards,
Chris.
Thu, May 8, 2008 at 9:08:12 AM | Finding and Replacing Text
revitcitydownloads
Thank you guys. I appreciate it.
Mon, May 12, 2008 at 10:08:38 AM | lab21
Dianthier
Dianthier Avatar
2.5 Stars: 3 Votes
Quoting lab21 from 2008-05-07 17:43:39
 HTH
Luke
 Where is the txt file? There is only an .ini and .dll file in the zip when I open it.
How do I install this?
Thanks
Diane
It's got to be happy hour somewhere
Mon, May 12, 2008 at 10:09:50 AM | lab21
Dianthier
Dianthier Avatar
2.5 Stars: 3 Votes
Sorry for the mess! for some reason I got double posted and I can't delete my post so I'm editting it, now I have another post I posted after this one.
I'm such a goober!
Edited on: Mon, May 12, 2008 at 10:16:48 AM
Mon, May 12, 2008 at 10:15:28 AM | Finding and Replacing Text
Dianthier
Dianthier Avatar
2.5 Stars: 3 Votes
Dang! Why did my question post doubles?
Mon, May 12, 2008 at 8:51:33 PM | Finding and Replacing Text
lab21
Sorry Here's the .txt file!
Luke
Overriding tag text w/o breaking link?
Thu, Jul 9, 2015 at 9:53:24 AM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:15 PM
Select all instances - finding the one
Sat, Jun 18, 2011 at 8:13:20 AM
Superscript/subscript/degree text symbols in Revit
Wed, Jul 5, 2017 at 9:10:49 AM
Finding Consultants who use Revit
Thu, Mar 10, 2016 at 1:45:54 PM
Page generation time: 0.2189
