Forums >> Revit Building >> Technical Support >> wood stud wall creator 3rd-party software?
Tue, May 6, 2008 at 7:24:19 PM | wood stud wall creator 3rd-party software?
Sandoz
1 Stars: 1 Votes
I'm in a revit group out here in Las Vegas, yes ppl. actually 'live' out here, and I was told that there is a beta software version floating around out there that will actually build a wood stud wall.  I've heard you can add a sill plating, blocking the whole nine.
Is anyone familiar w/ such a package?  If not what are some of the ways you're dealing with it in your neck of the woods?
I found this paper on the subject that may answer a few questions as to why Revit seems to lack a little in the wood construction dept.  Hopefully things will change w/ the advent of 3rd party software.  Here's a link to the PDF:
 http://www.lukewarmcoffee.com/revit/Modeling%20a%20Wood%20Structure%20Using%20Revit%20Structure.pdf
Enjoy and pls. share your experiences.
Fri, May 9, 2008 at 9:49:16 AM | wood stud wall creator 3rd-party software?
Sandoz
1 Stars: 1 Votes
Any 3rd party softwares out there that does "anything" like this?
Sun, Jun 28, 2009 at 4:12:19 PM | wood stud wall creator 3rd-party software?
Ajagg
Hello Sandoz
 Have you taken a look at MWF application offered by Strucsoftsolutions?  MWf is metal and wood framing extension to Revit. It works with both Revit Structure as well as Architecture. You can get more info at
http://www.strucsoftsolutions.com/mwf.asp
regards
George
Wood Stud wall
Thu, Feb 12, 2009 at 9:05:51 AM
3rd party to build Revit families
Thu, Dec 18, 2014 at 10:03:47 PM
Revit 3rd Party Artistic Addons
Wed, Jul 4, 2018 at 7:25:13 PM
Wood Stud Wall Cut Patterns
Mon, Feb 29, 2016 at 7:36:50 AM
3rd Party Doors
Sat, Jul 13, 2013 at 8:32:24 AM
Page generation time: 0.7390
