25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Section or elevations not cutting imported dwg's
Hello there, I am using revit arch. 2008. What I have done is imported coordinated mep cad files into my architectural model in revit. When I go to cut a section or an elevation, I see the whole mep cad files, and not just the view depth of the sections or elevations. What I am trying to do is to take an elevation of a wall and be able to dimension the wall with the mep's. ?? Is there a way that I can do this so that I can actually cut those cad files where the view depth of the elevations or sections actually work? I kind of just want the elevation of the walls with the protrusions?? Thanks JB
Sorry, I don't think you will be able to do what you want. Assuming they are 3D, AutoCAD imports are not cutable.
Thanks!
CAD objects can indeed be cutable. What I do is to import the *.dwg into an empty Revit project into an empty, in-place family component. Revit really sux at this btw and even small files can lock up your session. The largest file that I have used about 16 megs. Start a brand new Revit session if you have problems. The final step is to then import your component/project file into your working project file. There might be a difference if the 3d model is made of up from solids or a polymeshes. I have gotten this to work with ACIS solids.
Section cut through the imported dwg file |
Wed, Jun 26, 2013 at 4:00:40 PM
12
Section through a family object and imported dwg file |
Fri, Mar 26, 2010 at 12:41:24 PM
Revit Not Cutting Through Imported .dwg 3D Model |
Mon, Jan 19, 2015 at 2:05:11 PM
Cutting an imported solid in plan and section? |
Tue, Jul 29, 2008 at 9:45:49 AM
Topo Surface using ACAD dwg |
Fri, Jul 7, 2006 at 2:13:08 PM
