Forums >> General Discussion >> Revit Project Management >> Ground Material in Revit 2009
Tue, May 6, 2008 at 1:29:43 PM | Ground Material in Revit 2009
amjhd
amjhd Avatar
2.5 Stars: 3 Votes
Hello,  I haven't figured out how to show my grass.
Thanks for your help,
Tue, May 6, 2008 at 2:49:47 PM | Ground Material in Revit 2009
4 Stars: 205 Votes
Hi, it's simple, pick in the object, go to propreties and in "Materials and Finishes" choose in the left side one material for E.g. (site-grass), duplicate with another name "Grass1" then in the right side you have "Replace", pick them, "He" open and you have 3 type or grass, chose one of them, if you don't like anyone you can change, go to "color" and chose "image file" he open and you have the choise to select a JPEG or PNG image for another image you had download, select it and "Update Preview", the size of your image you can adjust after the render if you understand it is very large or very smaler... try it...
Anything else... Shoot...
Wed, May 7, 2008 at 12:41:55 AM | Ground Material in Revit 2009
amjhd
amjhd Avatar
2.5 Stars: 3 Votes
Thanks a lot!
I've done what you're saying before but I think there is an easier way.
Gray Ground Plane in My renderings
Fri, May 29, 2009 at 5:38:03 PM
Rendering Ground Planes showing up when i dont want them to
Wed, May 10, 2006 at 7:14:43 AM
ground plane rendering
Mon, Dec 7, 2009 at 3:50:25 PM
Revit 2009 Additional Material Request
Thu, Aug 7, 2008 at 3:21:22 AM
2009 subsurface material display
Thu, Apr 24, 2008 at 8:07:25 PM
Page generation time: 7.7594
