Forums >> Revit Building >> Technical Support >> slant walls
Wed, Mar 30, 2005 at 1:53:56 PM | slant walls
bayou66
3 Stars: 1 Votes
I confess - I looked around and tried a few things - but cannot get a slanted wall to work. Can you point me in the right direction ?
Wed, Mar 30, 2005 at 4:53:12 PM | RE: slant walls
rshank3499
if you select the wall there should be an edit profile button on the top bar im not sure what its called option bar maybe, im still new to revit myself, and it will take you to sketch mode where you can make the profile angled. i hope that helped
Wed, Mar 30, 2005 at 5:24:20 PM | RE: slant walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If your refering to a canted wall, then you would need to create an in-place family wall. Either that or if you still want to have all the layers of the wall, I'd suggest using a roof for the wall with a steep pitch... (unfortunately if you want to put any host elements doors/windows into this wall/roof then you will most likely have to edit/create new families to get them to behave correctly in the canted wall. My preference is for the roof option. HTH.
Wed, Mar 30, 2005 at 5:35:08 PM | RE: slant walls
bayou66
3 Stars: 1 Votes
I found a section in my book about doing it with model lines and then using the curtain system by lines method to create a glcursewall - this seems to work - but rather tricky. Let me know what you think. I am going to try your suggestions for the canted walls that are not glazed. Thanks Evan
Wed, Mar 30, 2005 at 8:56:13 PM | RE: slant walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I was going to suggest that method also, but it's a little more difficult when you require inserts. But hey, if that's all you need then by all means do it that way... Its faster and will behave a little better at intersections.
Fri, Apr 1, 2005 at 5:58:01 AM | RE: slant walls
fazerneil
4 Stars: 5 Votes
Could you not use "sculpted walls" tutorial by Mr GG to create your cant wall profile ?
Wed, Apr 6, 2005 at 1:15:50 AM | RE: slant walls
Bill Roseberry
I'm running into the same problem with battered stone walls. I've tried sweeps on wall types but I loose the windows; they are buried in the wall. I've tried the blend extrusion and it will create a wall you can put doors and windows in but you can't use it to replace existing walls in a layout. Not real user-friendly. Is there a useful solution or is this a giant bust in Revit?
Wed, Apr 6, 2005 at 1:45:36 AM | RE: slant walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
"I've tried the blend extrusion and it will create a wall you can put doors and windows in but you can't use it to replace existing walls in a layout" What do you mean by this? If you are having trouble placing inserts in the in-place family wall, you could create voids to cut the wall where the inserts need to go, then have a normal wall to the size of the opening and place an insert in this wall to its full extents?? HTH.
Joining Roofs with different slant angles
Fri, Apr 19, 2013 at 10:19:05 AM
Slanted walls in 3d [ 1 2 ]
Fri, Feb 23, 2018 at 10:05:16 AM
15
SLANT WALLS?
Mon, Apr 20, 2009 at 6:55:39 AM
joint slant and vertical mullion
Tue, Oct 23, 2012 at 9:05:43 PM
Slanted opening through wall
Fri, Feb 26, 2010 at 4:51:27 PM
Page generation time: 0.3157
