Forums >> Revit Building >> Technical Support >> Elevations
Wed, Mar 30, 2005 at 1:27:33 PM | Elevations
Hmeadq
How do I get an elevation to print correctly with line weights? I right now can find no solution but putting it in AutoCad, we are still in DD and I need a set by the end of this week, and I don't want to have to do that EVERY time I need to do an elevation... Thanks
Wed, Mar 30, 2005 at 3:21:00 PM | RE: Elevations
kfpopeye
Use the line tool. Select the type of line you want and then just pick the lines on the elevation to change them.
Wed, Mar 30, 2005 at 5:20:59 PM | RE: Elevations
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If using V 7.0. You can also use advanced model graphics-->enable silhouette edges. Then select the line thickness you want. HTH.
Problem with Interior elevations
Fri, Feb 13, 2015 at 1:51:29 PM
how to add elevations to door & window schedules
Tue, Oct 30, 2007 at 11:59:24 AM
Getting door elevations
Thu, Nov 21, 2013 at 6:12:08 PM
12
Editing Font on titleblocks below elevations/plans on sheets?
Tue, May 22, 2007 at 4:46:36 PM
interior elevations
Sat, May 2, 2009 at 11:28:06 AM
Page generation time: 0.1407
