Forums >> Revit Building >> Technical Support >> REVIT 2009 - MATERIALS
Mon, May 5, 2008 at 12:41:28 PM | REVIT 2009 - MATERIALS
4 Stars: 205 Votes
I begin with REVIT 2009 today and i open a old project made in RAC 2008, when i render, all the materials in my scene appears a kind of "Gray", i go to "Settings-Materials" and all off my materials created by 2008 are there but in "BUMP Material" don't show the JPG of my material, it's just like don't exist, only when i browse and choose the material in the BUMP folder "He" can render  correctly. Question:  Do i must assign  the  materials  (one by one)  again in Revit 2009? or there is a simple way to do this, "Push" all old materials in the project open with 2009?
Mon, May 5, 2008 at 1:01:40 PM | REVIT 2009 - MATERIALS
Thread Post Kudo! #2
TABEST
4 Stars: 4 Votes
Not 100% sure, but I believe it is the unfortunate, one by one option...  at least they managed to keep how the materials look in elevation and cut views!
Mon, May 5, 2008 at 1:05:57 PM | REVIT 2009 - MATERIALS
4 Stars: 205 Votes
WHAT???? ONE BY ONE???
Mon, May 5, 2008 at 2:15:43 PM | Typhoon
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting Typhoon from 2008-05-05 13:05:57
"WHAT???? ONE BY ONE???"
i think he means you will have to re-assign each material one by one in 2009?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, May 5, 2008 at 2:53:09 PM | REVIT 2009 - MATERIALS
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I read some info on this and it appears that Revit 2009 will convert some of the default materials. It will put a text string in the comments field of the Identity tab for each material that is not update. The string will read "Material appearance not upgraded." This is to let you quickley identify all materials that weren't converted.
Tue, May 6, 2008 at 12:33:33 PM | REVIT 2009 - MATERIALS
PeteGGA
i think if you open a default 2009 template file with the new materials, open your file, then do transfer project standards and tick materials, it should then redifine the materials and ask you if you want to over write existing.
Wed, May 7, 2008 at 8:29:29 AM | REVIT 2009 - MATERIALS
kesflower
3.5 Stars: 11 Votes
Even if you do a transfer project standards, for some reason it won't write ALL of your materials.  James is right, the best way to make sure they all transfered is to look for the comments.  Slightly a PIA...
Ruth Rau
Main Street Architecture, P.C.
Mon, Jun 23, 2008 at 12:06:36 AM | REVIT 2009 - MATERIALS
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Hey, I have a material where I need some parts to be transparent, and some parts need to be solid colours. Imagine the picture as a stud frame. I need the black parts to look like wood, and I need the white part to be transparent. Could someone please explain to me how I'd do this? Im using RAC2009, so the tutorial in resources doesn't quite help me.
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Mon, Jun 23, 2008 at 9:25:48 AM | REVIT 2009 - MATERIALS
TABEST
4 Stars: 4 Votes
I'm not sure this can be done... but I'm more of curious as to why?  I've noticed in Revit that there are a lot of times where you have to create a work around in order to get your desired effect...  I'm curious as to what you are trying to achieve, perhaps there is another way you can achieve the effect you are looking for...
Mon, Jun 23, 2008 at 5:54:29 PM | REVIT 2009 - MATERIALS
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Hey, I want to do this so I can create a house structural frame. I would just draw a normal wall, and then apply my custom material, so some parts are transparent and some are wood colour. I would like to render it so it looks like the image below, and the black part of my image would be the house frame.
Mon, Jun 23, 2008 at 6:08:56 PM | REVIT 2009 - MATERIALS
#11
TABEST
4 Stars: 4 Votes
I don't think it is possible to do what you want with a material, you can make a material see-thru, but I don't think you can make a complex material... What you really need is a framing family to show your studs...or place each "column" and brace etc...I've seen other people dwelving into this arena, creating families that show how a wall is framed, I'd love to do that, but our file size is already 200+ Megs and growing, so not in this project for us!
Mon, Jun 23, 2008 at 7:38:36 PM | REVIT 2009 - MATERIALS
#12
timbo89
timbo89 Avatar
4 Stars: 5 Votes
I think it is possible. I created a drafting view and used solid fill hatches to create my desired pattern. I created a generic material and used my drafting view pattern in the "cutout" attribute of the material, then applied any colour I wanted. The end result looked like the pictures. Its just a generic wall with my applied material.
Tue, Jun 24, 2008 at 9:32:53 AM | REVIT 2009 - MATERIALS
#13
TABEST
4 Stars: 4 Votes
Now that is pretty cool, if that is't new to 2009,I definitely missed that in 2008!
Tue, May 5, 2009 at 10:01:40 AM | REVIT 2009 - MATERIALS
#14
RfOeCnKdOeNr
4.5 Stars: 4 Votes
I know this is an old post but I found it google searching and I figured this would help anyone else who finds it...
 I created a tutorial on how to Create Custom Materials:
 http://therevitkid.blogspot.com/2009/05/tutorial-custom-material-creation.html
Duplicating Materials in 2009
Fri, May 16, 2008 at 1:16:25 AM
materials appearance - revit 2009
Thu, May 29, 2008 at 1:11:15 PM
using revit 2008 project in revit 2009...plz help
Tue, May 27, 2008 at 8:44:38 AM
New materials RAC 2009 and or new skies/backgrounds/environments??
Thu, Jan 22, 2009 at 7:03:18 PM
Adding materials into Revit's materials files
Thu, Jul 22, 2010 at 1:54:48 PM
Page generation time: 1.5563
