Forums >> Revit Building >> Technical Support >> brick cap at top of wall
Wed, Mar 30, 2005 at 11:45:24 AM | brick cap at top of wall
rshank3499
i want to put a brick cap at the top of a wall. i want it to wrap around the top of the wall, all four sides. does anyone know how to do this? thanks in advance, R.Shank
Wed, Mar 30, 2005 at 12:02:07 PM | RE: brick cap at top of wall
arnosandoval
5 Stars: 3 Votes
WHen you create your wall, you can add sweeps/reveals etc. to the wall, that way it becomes part of the wall family. If you select your wall you you go to edit, edit structure. When the window pops up go to preview, you will get a preview in plan, switch from plan to section. When you do, you get more buttons to work with. Click on the sweep, and add you cap profile. Hope that helps
Wed, Mar 30, 2005 at 2:20:18 PM | RE: brick cap at top of wall
rshank3499
THANKS ARNOSANDOVAL, IT HELPS ALOT BUT I CAN GET THE SWEEP IN THE SIDES ON THE WALL. ITS JUST A 2'6" LONG PEIR AND I WANT TO PUT A CAP ON THE TOP
Wed, Mar 30, 2005 at 5:18:51 PM | RE: brick cap at top of wall
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Rather than embed the sweep in the wall type, I'd suggest just using a hosted sweep, wall sweep with the appropriate profile. This will allow you to wrap around the ends of the wall also. HTH.
Tue, Jul 22, 2008 at 9:51:36 AM | brick cap at top of wall
snap698
With a host sweep I still am unsure how to get the parapet cap to wrap around all 4 ends of a wall. I have a free standing wall my wall cap leaves 2 ends open??  Thanks in advance.
Edited on: Tue, Jul 22, 2008 at 10:30:17 AM
Tue, Jul 22, 2008 at 10:23:36 AM | brick cap at top of wall
4 Stars: 205 Votes
Hi SNAP, "I need a parapet cap to wrap around the end of a wall., to do this you must create a family "Generic Model Face Based", If you want to create a sweep or reveal, you must create a family with the "Profile" or "Profile-Hosted"... i prefer the last because in there we can choose if we want sweep, reveal, fascia, gutter and so one...
If you don't get it tell me and i create a video for you...
Edited on: Tue, Jul 22, 2008 at 10:32:32 AM
Tue, Jul 22, 2008 at 10:34:14 AM | brick cap at top of wall
snap698
Typhoon, thanks alot for your help...if you could walk me through that process that would be great.  Im still fairly new to this software.
Tue, Jul 22, 2008 at 10:39:06 AM | brick cap at top of wall
4 Stars: 205 Votes
Hi SNAP, can you wait? it's take a several minutes...
Tue, Jul 22, 2008 at 10:52:33 AM | brick cap at top of wall
snap698
sure, there's no rush...
Tue, Jul 22, 2008 at 11:06:50 AM | brick cap at top of wall
4 Stars: 205 Votes
SNAP this is the 1º video: http://screencast.com/t/GZnakMtV
i'm create the second ok? see this....
Tue, Jul 22, 2008 at 11:13:21 AM | brick cap at top of wall
snap698
Tue, Jul 22, 2008 at 11:21:38 AM | brick cap at top of wall
4 Stars: 205 Votes
This is the second video, i think you go understand, sorry for my bad english: http://screencast.com/t/UlBBX7gVcPi
Tue, Jul 22, 2008 at 12:01:04 PM | brick cap at top of wall
#13
snap698
typhoon, thanks alot for your help!
Tue, Jul 22, 2008 at 12:12:20 PM | brick cap at top of wall
#14
4 Stars: 205 Votes
You Welcome SNAP...
Thu, May 5, 2016 at 10:00:56 AM | brick cap at top of wall
#15
BEKINCAI
can you send me the videos on how to do this. the links in the thread are no longer active.
im trying to find the easiest way to model this CMU wall with the brick trim all around. see pic
thanks
Sloped top of stone wall with wall cap on top
Tue, Mar 29, 2005 at 5:25:07 PM
Precast Cap on wall profile sketch
Thu, Mar 23, 2006 at 2:31:12 PM
Wall Sweep for 2 x 6 Sill and 4" Cap Block
Thu, Feb 11, 2016 at 9:15:08 AM
Brick wrap around the top and sides of CMU wall
Tue, May 10, 2016 at 10:04:28 AM
adjusting railing top cap extension
Tue, Mar 3, 2009 at 3:22:46 AM
Page generation time: 0.6687
