16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Scheduling Curtain Wall Components
41 Posts No Rating |
Where do I find mullions on a schedule? How do I Split a door Hieght from a Header height in a curtain panel? How do I seperate a trim over corner from the frame I had to draw it on top of and insert it as 1 mullion? How do I get a 10'-0" tall panel to scedule as 10'-0" tall when it has to scew to a top and bottom 2" track that have to finish 10'-0" apart, it cuts where the panel crosses the mullion?How can I use formulas in shared parameters, ie anel hieght-headr = door hieght? I am having trouble with showing a relationship between parameters almost everywhere. Is it posible to use a width parameter to change door sizes on curtain doors like I do on standard wall doors? I often have to go from a wider door with a smaller frame to a smaller door with a larger frame to avoid columns. It took me a lot of time to build families profiles etc to make my drawings look right but no one cares how they look all they want is how much it cost and what pieces and how many to ship and by using curtain walls I cut my drawing time by about 75% but if it will not count it is useless. I had to use a void region to make 20" panels fit in 15" holes. How do I get them to count right? Is there a way to schedule that subtraction? Maybe just a lenier footage of unhidden panels? Please help
This post is too confusing. I think you need to seperate your questions into several posts and include some screen shots that will help describe your problems. Have you worked through the various tutorials available on curtainwalls? I don't think this is what you meant to ask but this is an answer to part of your question. "How do I get a 10'-0" tall panel to scedule as 10'-0" tall when it has to scew to a top and bottom 2" track that have to finish 10'-0" apart, it cuts where the panel crosses the mullion?" ???? If you want your panel to be 10' inside of mullions then you need to set the grid accordingly.
If you are a member of AUGI, the handout here should help you. http://forums.augi.com/showthread.php?t=77167&highlight=curtain+wall+handout
That was a fun post. Never thought of using panels as mullions. but his answer to my ultimate problem of scheduleing mullions was "be creative". I am trying but it is hard to count. Maybe I will repost with examples when I put the files on a computer with internet.
Retaining Curtain Wall Door Scheduling Data |
Thu, Jan 8, 2015 at 2:47:08 PM
Curtain Wall scheduling |
Mon, Feb 7, 2011 at 12:36:05 PM
Curtain Wall Door as Legend Components |
Mon, May 19, 2014 at 7:55:50 PM
How to place Curtain/Glass Door for Curtain Wall for Revit Architecture 2012 |
Thu, Jul 7, 2011 at 4:27:10 PM
scheduling dissimilar components |
Wed, Mar 9, 2005 at 9:07:38 PM
