9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Revit filled regions
3 Posts No Rating |
Hi I'm a new REVIT user using REVIT 2008. I was just wondering how you can change the border on a filled region. Can you change a filled region to have no border? The same for masked regions - how and where can you change the border-line properties...if at all...
You can use different lines when you create either of these regions, just select what you want from the drop down on the options bar. That includes invisible lines.
Revit 2014 Filled Regions |
Fri, Jun 27, 2014 at 4:47:56 PM
11
Masking Regions and Filled Regions BEHIND 3D Objects |
Wed, Aug 1, 2012 at 8:10:27 AM
Filled Regions and families |
Sun, Mar 8, 2009 at 7:10:29 PM
Filled Regions on an elevation |
Wed, May 25, 2005 at 1:35:38 PM
filled in regions |
Mon, May 2, 2005 at 1:08:09 AM
