21 Users Online (19 Members):
Forums >> Revit Structure >> Technical Support >> leader without text
i need to draw leader without text is that possible?
Why don't you build an annotation family for this and post it here?
42 Posts No Rating |
Check the downloads section "Uncategorized" for blank leader; I believe I found one on here. It has no text associated with it, and you have the option for multiple leaders. HTH
I've had the same need... leader without text. My solution has been to simply use a "period" as the text. This allows me to use the same arrow styles that are used WITH the text. If the period looks to messy, perhaps you could use an "invisible font" or a blank "wingding". My leader is attached in the project below. Dan-o
13 Posts No Rating |
You can also just make a new text type that you name NO Text. On that, make the text really tiny where it wont print out.
Multiple Leader Text |
Sun, Nov 18, 2007 at 12:33:40 PM
ARC LEADER NO TEXT |
Thu, May 2, 2013 at 10:36:04 AM
Distance from leader to text... Revit 2010 |
Tue, Jun 1, 2010 at 9:13:51 AM
distance between text and leader lines able to be changed? |
Fri, Sep 12, 2008 at 10:20:21 AM
drawing a leader/arrowhead without text? |
Mon, May 31, 2010 at 10:54:51 AM
