Forums >> Revit Building >> Technical Support >> structural deck
Fri, May 2, 2008 at 4:16:25 PM | structural deck
emosms
hallo
can you tell me the use of structural deck.maybe naive, but i thought it is a deck with a section of some repetaitve structural member within Cryingsome joists or beams) at a certain distance, this way saving some detailing drafting afterwards.but when i set a structural deck layer with a deck profile loaded within a floor slab, i see nothing in a section view even at detail level set to fine.some filled layer with a pattern defined by the material assigned (of course) and thats all.then i have to detail my floor joists profiles manually.
what do i misunderstood?
what is the purpose of the structural deck layer?
Best Regards
Metal Structural Deck on Floor
Tue, Jul 12, 2005 at 10:06:29 AM
deck profile is not loaded
Mon, May 5, 2008 at 1:29:01 PM
Parts / Structural Deck Visibility
Mon, Jun 15, 2015 at 5:00:30 AM
Aligning Deck Symbol Annotation to Deck Edge
Tue, Sep 4, 2007 at 12:21:20 PM
Roof to follow sloped structural steel
Wed, Sep 22, 2010 at 4:11:16 AM
Page generation time: 1.1014
