Forums >> Revit Building >> Technical Support >> Help With Doors Please
Fri, May 2, 2008 at 1:27:32 PM | Help With Doors Please
Jbajek
I am creating a door library for our office and need help with how I should go about doing this.  Should I create frame profiles and door panels in seperate files and bring all of them together in a nested family?  If so, what is the best way to do this?
Tue, May 6, 2008 at 10:27:21 AM | Help With Doors Please
Dafpfy
3.5 Stars: 11 Votes
yes you should,
and i gues you will find the rest as you go allong,
parameters made in for example a frame can be overwrited in the familie you load it in with an other parameter made in that familie,
i set all parameter that should change automaticaly in the category 'other' and then link em to the imported familie,
ex.
Doorpanel width : formula : Width - (2 * Doorframe Thickness)
you can olso change the door panel if two doorpanels are loaded into the familie, with the familie parameter
Uber doors are olso possible Smile i have a door that has sidewindows or not, only left or only right and a window above or not,
and all the glasstypes can be changed with a click of the mouse
same for the doorpanel
little warning on that part , Revit takes allot of thinking in changing anything in that door but hey,,, atleast its not my brain cracking anymore :pSmile
Edited on: Tue, May 6, 2008 at 10:35:50 AM
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Anyone have pocket doors or pivot doors?
Tue, Jun 25, 2019 at 12:37:56 PM
dOORS AND DOOR SCHEDULES
Mon, Aug 6, 2007 at 11:28:15 AM
Curtain wall doors wont center up
Mon, Oct 12, 2009 at 4:28:48 PM
doors opened in 3D views
Wed, Sep 27, 2006 at 9:20:29 AM
Doors not appearing in door schedule... Help
Thu, May 30, 2013 at 11:58:43 PM
Page generation time: 1.5598
